How To: Rear Light De-chrome
Here's a quick guide on how to separate the rear lights. This is a pre-facelift, so may be slightly different on a facelift set.
Carefully remove the foam tape from the edge and rear of the light, and Dremel round the edge where you can see they've been stuck together:
Carefully prise open, Dremeling some more if you haven't cut deep enough:
Locate the 3 or 4 stamped areas round the outside - these will be directly opposite the 4 tabs / holes you can see round the edge of the lens:
...mine only had 3 stamped areas, but some have 4.
