1 - 2 of 2 Posts
I've come across a cheap set of R56 APs, before I pull the trigger on them I just want to make sure that they'll fit. I know the rears won't fit on the R53 standard setup but from what I understand, if I swap the rear trailing arms to R56 ones (something I've considered doing anyway and this would give me the perfect excuse to get arsed to do it) they should fit perfectly right?
Also, are all R56 rear trailing arms the same? Or is there a different one for the Cooper S?
That's you, that is.
You’re correct - R56 rears won’t fit R53 arms as they have a conical attachment point which fits into a concave “socket” on the R56 arms. Definitely a good excuse to swap to lighter R56 arms! . Yes, they are all the same.
1 - 2 of 2 Posts
