Hi all, in need of help please, I have an R50 and I've upgraded the rear to R56 trailing arms etc, new discs/pads HB cables and new R50 speed sensors with adapters so they fit, I didn't use R56 ones as I've been told the ECU won't like them?
So I've bled the brakes,adjusted the HB been on a test drive and the ABS light comes on after driving for one minute roughly along with the tyre pressure monitor even though all the tyre pressures are spot on.
I've replaced the rear left wheel sensor for another new one and put a brand new hub on the rear left and after clearing the fault the light comes on again with the exact same fault registering!
Also you can feel the pedal do the ABS pulse gently when you brake sometimes aswell, which it never did before.
I'm pulling my hair out as I've no idea what to try next??
