Hi all.
Wanted to document my R53 track toy project to date, and then somewhere to keep a note of future changes - just in case anyone is interested really!
Bought a 2003 R53 semi track converted (badly) in February 2022. Always wanted a bona fide track car, and was torn between the Clio 172 Cup and an R53. An R53 came up at the right time and price, so the R53 it was. Had covered 100k almost on the button. Came fully stripped with Bimarco seats and harnesses, OMP steering wheel on a snap off boss, uprated intercooler and a 15% pulley (which turned out to be for something else and didn't fit properly). Oddly, someone had desperately tried to make this Cooper S look like a Cooper!?
I've done a fair bit of track over the years in various cars I've owned, and decided to track day initially in March at Keevil Airfield (close as I'm south west based) to test it out. Airfields are great as LOADS of runoff in the event of running out of talent. In prep for this, I spent a bit of money on some of the essentials, so on went some R56 Cooper S brakes, EBC pads, braided brake lines, and some Toyo Proxies all round. I also removed the old 15% pulley and replaced it with a KAVS 17% instead. Once done, I went to a good friend of mine's rolling road to check primarily what the fuelling was doing with regard to AFR - no one wants a lean engine on track.
She managed a surprising 207 flywheel horsepower on those minimal mods, but the interesting thing was how unbelievably rich the fuelling was! I'm usually targeting a WOT AFR of around 13, the R53 was well into the 11s and lower which I personally think is too rich - but that's a matter of opinion. Regardless, a safe AFR for tracking so off we go.
A photo from the Keevil track day - (poor quality):
Verdict on track day 1. Awful. Brakes were tragic, half a lap and the pedal was long. Tyres weren't great, but to be fair, the surface wasn't either. Lots of engine braking that day. Still, it made it home happily enough - although with much to do and money to spend.
Next track day was booked for Castle Combe in June, so the spending started in earnest - much to my wife's delight.
First change wasn't a choice, the timing chain tensioner packed up on the next start, so that was the first job to do. When changing the chain, it seemed rude not to change the camshaft as well for a Newman cam - so in that went at the same time.
Inside the cylinder head was in really good condition - turns out looking through the limited history that came with the car, it's had a new one.
Other changes happened at the same time as well, addition of a strut brace (upper front), replacement of cheapo CAI with a Ram Air cone (mostly for the charger whine), various hose replacements, brake fluid change for Motul RBF660, EBC Yellow Stuff pads front and Mintex 1144 rears. I also removed the stock spoiler and fitted a JC Slick rear wing.
Another issue that needed to be solved was the airbag light on the dash. Both annoying, and an MOT failure. Broke out my old BMW software laptop and used NCS Expert to recode the airbag module to remove the airbags from the module itself. Airbag light problem solved.
I broke out another old laptop from back in the day which has WinOLS and ECM mapping tools on it. Using a clone MPPS cable, I grabbed a copy of the map on the ECU to have a quick look at. Interesting to say the least, especially because the map isn't clear as to what is what. An interesting fact though, is that the stock Cooper S map (at least on mine) has a very simple derestriction built into it. Looking at the throttle pedal map (I've put a copy in below for reference), above 5400 rpm, and at a pedal angle of 67% or greater, the map actually closes the throttle body progressively to redline.
With the new cam installed, I was expecting some changes to fuelling due to the change in duration of the cam, and also the fact that I had flattened out the throttle pedal map to give full whack and flashed it back, so back to the dyno we go to check we're safe for a day at the track. Dyno plot below shows before and after the cam install - very clear that it comes on from pretty much bang on 4000 rpm. Bear in mind at this point it is on a totally stock map (except for the throttle map bit) and stock injectors.
The power gain from really the cam alone was 14 flywheel horsepower, and the ambient temperature was quite a bit higher which will affect power. That plot doesn't show AFR annoyingly, but I can confirm that it had lifted so that AFR was now in the low 12s instead of the low 10s towards the top of the range. So, happy with that, and off to the track we go again.
Verdict on track day 2. Better. Brakes were very good and didn't suffer from any real fade - the new pads and fluid definitely did the trick there. What did let me down on a 'proper' track, was the Toyos. My god they were awful, absolutely tortured all day long and went off really very quickly. But, again, a good day and the car drove home to fight another day.
A few photos from track day 2:
So then, to the tyres. First off, I managed to get hold of another set of wheels for £100, which needed some love and a paint. I also ordered a set of 4 Zestino Gredge 07R medium compound semi slicks. A friend uses them and recommended them based on price vs performance. On they went.
I also managed to get hold of a map file from a Cooper S JCW 200 BHP. When looking at the map in WinOLS, it was identical to my Cooper S map, except in places, there was more of stuff - that's about as technical as I can be as I don't have the map layout to say what is what. The Cooper S JCW 200 map also didn't have the throttle body restriction I talked about earlier. As the JCW 200 has the same injectors as the Cooper S, I checked that I was happy with my slightly modified version of the JCW map and flashed that on. It's not been back to the dyno as yet to identify any changes in power of AFR, however, it does certainly seem to go better, and a slight rev hang I had with the Newman Cam went away as an added bonus.
Track days 3 and 4 have both been at Castle Combe (because it's extremely local!) and have been great fun. The semi slicks have absolutely transformed the car, and it is now very capable on the track, and can hold it's own very well.
A photo from Track day 3:
On track day 4 I downloaded the TrackAddicts app and used my phone in a mount to record one morning session and one afternoon session. These are on YouTube and can be viewed here:
R53 Morning Session
R53 Afternoon Session
Best session was the morning with best lap of 1:25:37 which is respectable. I want to be down into the 1:1x:xx range next year!
And that will now be it for this year - it's in the garage amongst the firewood awaiting maintenance.
A few jobs to be done over the winter - clutch slave cylinder, supercharger inspection (and likely replacement as I think it's poorly), bypass valve replacement, water methanol injection, track rods and ends, full wheel alignment to bring the toe of both front wheels out very slightly, half cage, further lightening, battery tray removal, race battery, new straight exhaust, 550cc injectors, a proper map!
If anyone's interested, I will update this thread as these things get done. Else I'll be back about this time next year!
R53 Morning Session
