Have stripped out my car over the months and today weighed a few bits .
Battery - 13.64kg
Roof Glass inc seals, motor, inside panel - 25kg
Battery cable - larger of the two red ones - 2.3kg
Chrome petrol cap and emergency release pull - 0.68kg
Battery box and heatshield underneath - 4.55kg
Electric Window mechanism per side - 2.5kg
Under bonnet insulation
Firewall insulation pad. 4.9. (10.8)
Boot with glass, no wiper. 12.7 (28.0)
A/C compressor. 5.4 (12.0)
A/C-heater-blower assembly. 8.5 (18.6)
Brake booster. 2.7 (6.0)
Four gas struts for boot/bonnet. 1.0 (2.3)
Clutch/brake pedal assembly 2.9 (6.5)
Steering wheel airbag. 1.4. (3.1)
Upper steering column. 3.7 (8.1)
DSC pump. 2.5 (5.6)
Interior fuse panel. 0.7 (1.5)
Engine fuse/relay box. 0.9 (2.0)
Bonnet latches 0.9 (1.9)
Inner arch skins -no paint- 2kg
Door + Internals (No panel, with-out glass ) 23kg
Front side windows----- windows weight 8.1kg (4.05kg each)
Rear bench + Cargo cover: 16.1kg
Rear head rests: 1.8kg
Front seat - each
Door cards
Rear side panels
Boot panel
Speakers
radio
passenger dash airbag
Rear side windows------ All weigh in at 17.2kg and the plastic lexan
Rear window-----------
Rear control arms
Rear Anti Roll bar stock vs Ireland Engineering - 1.4kg weight saving
Rear steel training arms - no hubs vs Alloy R56 arms - 2.5kg weight saving
Standard manifold and cat vs Janspeed
Also removed the stock clutch/flywheel but the CM one was on before I thought to weight it :mads:-- stock flywheel 12.7Kg CM 5kgs
I have removed the steel trailing arms , upper control arms , Rear AR bar and will post up another day as to what weight they are .
Battery - 13.64kg
DSC pump. 2.5 (5.6)
Front seat - each
Door cards
Rear side panels
Boot panel
Speakers
radio
Rear control arms
