1 - 12 of 12 Posts
2011 R56 N18 Mini Cooper S - 2012 R56 N16 Mini One
So.
I have my baby booked in for a walnut blast on friday.
I am wondering if there are any possible downsides/issues this may cause?
Anyone have any experience?
Discussion Starter · #5 ·
The results are in.
2010 R56 s 68000 miles
Bottom 2 pics are before - not bad at all really considering mileage. No invoice evidence of it being done before.
Top 2 pics are after - super clean.
Nose Eyebrow Eye Facial expression Vertebrate
Also finally fitted boost solenoid under intake.
Calculated boost graph before solenoid fitted
Nature Slope Organism Font Technology
and after...
Slope Font Terrestrial plant Rectangle Gas
Certainly feels like more consistant boost now.
Not sure what the graphs show still digesting data.
Think the after graph must be wrong though - cant be getting over 30psi at 4k revs surely????
Probably not 30PSI on standard or mildly tuned car, maybe the app is calculating something else into the equation.
Still looks healthy on the engine if it has never been done before.
JCW N18
No cons on that. Only pros
Im into blasting my intake+exhaust valves next week too.
Im curious what about mine. I have 70k km(not miles) and im sure previous owner never did it.
As I understand it, valves could be blasted every 15-20k and it will make a difference to performance. If you run meth I guess that might extend that a little longer especially on direct spray.
Had the same problem with carbon buildup on my 2009 R56 JCW exhaust valves at 50,000 miles.
Built my own kit and took is slow for a 2 day tear down and blast over a weekend. Much improved...
Not too bad of a project....
Before
Water Eye Liquid Automotive lighting Window
After
Gas Auto part Household hardware Close-up Metal
Top of piston
Automotive tire Water Rim Automotive wheel system Tire
My DIY kit I built to walnut blast the valves
Vehicle Tire Automotive tire Car Hood
1 - 12 of 12 Posts
