Wagner Pre-Facelift R56 FMIC - Testing/Review
33999 Views 183 Replies 24 Participants Last post by  George Talbot
14
I was lucky enough to be sent Wagner Tuning's new FMIC for the Pre-Facelift R56 Cooper S. In agreement of receiving the FMIC, I organised a days testing at 1320 to see how this performed against the stock FMIC and how it performed with a Map on it.
Here are some pics:
Wagner FMIC (black) Evolve V1 FMIC (silver).
For me, there was a huge difference in quality and feel between the two FMICs, I had a long chat with Paul (PD240) about them and he was very impressed with the quality of the Wagner FMIC stating it was the best he had seen from any FMIC. I was very surprised to put my fingers down the feeds of both FMICs and have a very different experiance (no ****)....
With the Wagner, everything has been smoothed for optimal air flow whereas with the Evolve it has jagged edges and the joins and entry and exit feeds are very messy and do not look as efficient or optimised as the Wagner.
However, it must be said that the Evolve is a tried and tested product that works well as MinIan proved on Saturday with good results. I am looking forward to testing out this new FMIC from Wagner and it wont just be Dyno testing, will also included day to day driving performance.
Here are the temps, WHP, WTQ, Tune and Other items used during the day:
As you can see from the data, running the stock FMIC with the stock tune, temps roughly doubled, when the 1320 tune was added, temps increased by about 2.5 with the best run having 191 whp and 221 wtq.
Then we swapped the stock FMIC with the Wagner FMIC to see how it performed with the 1320 tune as we had already seen before in a previous review that the Wanger had performed well with the stock Tune.
As you can see from the data above, running exactly the same setup as stock, it lost 2-5 whp against the best and worst runs with the Stock FMIC and about 5 wtq. However, the main thing we are looking at is the intake temps, as you can see the starting temperatures to finishing temperatures varied by about 5 degrees which is excellent when you compare them to the stock FMIC intake finishing temps.
What this enables the car to do is maintain boost better as the temperatures are much lower, it also makes it a hell of a lot safer when applying more boost when tuning and allows you to take the car further.
Here is all the dyno graphs from the day:
Stock Map + Stock IC
1320 Map + Stock IC
1320 Map + Wagner FMIC
Best runs of each:
Exhaust + Intake Comparison:
Final Tune:
I would like to thank Mark from Wagner Tuning for sending me one of these to test for you all and show how it performs. I would also like to thank Thomas, Scott and Jack at 1320 for preparing the car and running all the tests and logs on the car and for a fun day out.
please post any questions if you have any.
Reactions: 4
1 - 20 of 184 Posts
Interesting stuff. Did you have the Evolve IC there on the day? Would have been good to see the comparisons across all 3...
Nope, the Evolve was not mine as it went on MinIans car at Lohen, I think 1320 have an Alta on their R56 so maybe in future we could test that.
MinIan does have some data for the Evolve though as his tests were run in similar conditions.
Reading this, and a little head scratching to answer why on earth are you loosing power instead of gaining with a FMIC, it just stroke me...HAVE ANY OF YOU REPLACED THE PRE IC BOOST TUBE WITH THE HUGE RESONATOR/RESTRICTOR ON IT?
Maybe this is to blame...
Just saying...
I tested the stock, the Forge and the Evolve V2 with various tunes and ALL dyno data were GAIN after GAIN...
I run the Samco boost hose kit.
Even if you don't want to buy expensive silicon tubes, you can eliminate the Resonator replacing it with a simple aluminum pipe.
Please try it...before I loose my hair :laugh:
Auto part Automotive engine part Automotive super charger part Air intake part Automotive brake part
Number 9 in that photo is the resonator. It won't harm whilst running with the stock IC and the stock boost pressure, cause it was designed to, but becomes a problem when running a 250% larger in volume IC. Flow is messed up big time, even more with higher boost pressure!
This restrictor was designed to eliminate the compressor's spinning noises when boosting. Together with that it achieves to erase any turbo lag, but with the stock boost levels!
Once you alter the volume of the boost hoses system (adding a larger IC) you need to get rid of this unwanted restrictor, cause what you are doing is, you are filling your new larger IC with air that is traveling too slow, hence the unbelievable cooling effect of only +5oC inlet and outlet. What you want to do is to allow air to flow unrestricted into your IC, let it do it's job and gain from it.
That's my understanding and my experience together, and don't worry about turbo lag...your tune is taking good care of it!
Reactions: 5
:thumbup1:
@OP:
Can you please add, what's the equipment used to measure various temps and the location of each reading?
Also, what's that engine temp? Engine bay temp? or coolant temp!?
These are vital during tests in determining the efficiency of products.
Thanks George.
ps: just read my own posts and they come a little harsh me thinks...this is not my intention people, I am just trying to add knowledge to an already very well written thread (thanks to George for the effort of testing and the nice write up). These kind of threads is what MT is ALL about! :thumbup:
I thought that evolve tested the forge resonator delete pipe and it actually lost power with it the forge pipe on Si they went back to stock?
Also the Evolve V1 that was tested at Lohen was a straight swap and running the stock resonated feed pipe and that made 6bhp...
With stock boost pressure?
Let me see if I can find it in their thread...
Just saying...
Interesting, very interesting. If this is the case and we need to provide something else in the kit to remove a restriction up stream we can look in to it.
But if some are fine without removal kind of blows that all out of the water.
Saying that though, our coolers are designed to flow well, distribute the air flow as evenly as possible across the cooler matrix and remove as much heat as possible. Without costing too much!
Maybe ours flow better than others so the resonator is causing issues when it comes to power? We are very happy with the cooling but going by experience with other cars would also expect to see more power at the same time.
Forgot to add that I installed my scan gauge 2 tonight on the way home to record IATs...
Outside temp ranged from 8.5-9 degrees.
Started the car and initial reading was 12 degrees. My journey is about 20 miles, half motorway and half city driving. The first half was city driving, stop start for 15 minutes and the temps ranged from min 11 to high 17 degrees. On the motorway cruising at a constant speed it sat between 11-12 degrees, during the journey I had a few moments of full boost to see if I could make the temps climb but it didn't really move which is very impressive.
Looking forward to seeing how this performs at Snetterton.
George,
Would you say that the car was more capable of handling the 1320 tune because of the FMIC
I.E Was the car tuned pre inter-cooler and results recorded on the 1320 tune in respect of temps?
**EDIT: Being a dick and not reading things properly...
5
I will purchase a Samco kit soon.
Which one is it Thepenl?
SamcoSport UK - Car Kits
This is the coolant hose kit
Auto part Automotive radiator part Automotive super charger part Air intake part Automotive engine part
This is the intake hose kit
Material property Air intake part Auto part
And this is the boost hose kit (5 pieces)
Air intake part Auto part Pipe Automotive super charger part Automotive engine part
And some photos of them fitted to my engine.
Land vehicle Car Vehicle Engine Auto part
Vehicle Engine Car Auto part Fuel line
My car had never been tuned before Thursday
It went as follows:
Stock IC Stock Tune
Stock IC 1320 Tune
Wagner IC 1320 Tune
With the much lower temps, it will hold the boost and make it safer when mapping with even higher boost levels. I am sure with 99 Octane it would be 230+bhp, my car uses 97 as 99 is not easily available and wanted to keep it fair for testing.
Temps wise, this is probably the best FMIC on the market at the moment, power wise, really not sure....
I am guessing then that boost hose kit is the one I need to remove that resonator?
Sorry... Any idea what boost pressure is?
So Wagner/New Hoses/Tune = 200WHP?
Yes
From the boost hose kit photo, the longer tube is in fact the replacement of the resonator.
1 - 20 of 184 Posts
