1 - 20 of 262 Posts
Screaming Devil!
Mods:
-Custom cooper exhaust
-Autometer Boost gauge
-Powerflex bushes:upper and lower engine,,gearbox front lower bushes,rear trailing arms.
-JCM upper strut
-949Racing 6UL 15x7 ET36 Matte Bronze wheels wrapped in Federal rsr and bbs RG-F 366 16x7 ET 36 in gold with yoko A048
-M7 grills
-Teflon coated charger with 15/17/19 pulley
-R56S front and rear calipers,Performance friction 2 piece discs front- CB XP12, brembo drilled with CB XP10 in the rear
-Interior weight reduced
-Kw Challenge coils (2 way adjustable)
-Whiteline bar
-Mynes V2 exhaust manifold
-Powergrid droplinks front and back
-Hfs 3 water/meth system
-Omp steeringwheel+Quick release steering wheel boss
-Sparco evo 1 buckets
-Schroth harnesses
-Bolt to stud and nut conversion
-R56S/R53GP alu trailing arms
Parts waiting to be installed:
-GP sideskirts
-Mocal oil cooler
-JCM wing
-Dimples in oil carter, SC and gearbox
-Oil pressure and temperature gauges on adapters
-Orranje brake ducts
-Cat cam
-Oil bypass plate
-Mocal inline oil stat
-Ati crankshaft damper
-OS GIKEN clutch
-550cc injectors
-Quaife LSD
-Arp nuts and studs
-Cosworth head
-Mini Garage a like front mount
-Challenge aero front bumper
-Oem fuel pump with walbro support pump
-Baffled sump
Work to be done
-Balancing crank
-Hone
-New rings,bearings
-Clean lower block
omd
i like the 16's they look purposeful... get some coilovers on it, Floofs car with 16's was awesome!
any sounds clips of the bastuck? And any better picks of what the tips are like?
freedom...blah
Sounds like this is going to be a very tasty motor :D
& that OS Giken clutch was a steal!
Screaming Devil!
Here some pics of the Bastuck,i will make a soundclip later.The other Belgian dude and fellow club member (Dangixxer) has the same one on his.He made some soundclips before.They're on you tube aswell.
Screaming Devil!
Has your thermostat gone? Nice looking car looking forward to seeing this progress
Not sure yet,i have a spare one left and a M7 on order.Can't find any marks of a leaking thermostat...I do have that smell(hot water) coming in the car..I only changed out the standard for gp intercooler lately..
BRG R53 Cooper S
Cool car dude sounds like your heater matrix may be leaking though It's the only thing that is inside the car that's got hot water and will cause fogging of the window:sad:
Reactions: cooperke s
Screaming Devil!
Discussion Starter #11
What do you mean with the heater'matrix'?
I have a leak :w00t:,that's for sure now!
My observations:
-smell of coolant
-green colored puddle of water near the gaspedal(left hand drive),kinda sticky stuff
-i have no airco on,i do have the auto system
-the driver side of the window does not fog :glare:
-coolant level drop a bit
-i have a consistent water temp on scangauge
All these observations indicate its a coolant thingie,the only thing that's inside is the heater core,yes???
I need to open this can of worms a bit more,hope it stops raining this week that i can do some work,i hate that shitty weather ::getcoat::
Can this be A/C related?A/C is running on liquid gas or something?
Thanks in advance!
Tom.
Screaming Devil!
Discussion Starter #12
Finally had some time 2 fix the leak and put some stuff on that's been in the garage for way 2 long.
Well the problem was the heater matrix indeed,when removing the matrix it showed some traces off coolant.
As you can see in the picture i could'nt cure it like it should be;to much hassle to get this right and i already got something in mind if this should go wrong.So i got the ghetto solution and put a tube on there.No heating for now,but it's summer anyways...:tongue_smilie:.Thanks anyway Brownpants,your matrix is in the garage and will be mounted later on or not if i decide to get rid of the heating and aircon.
Further on,i decided 2 put on the teflon coated charger with 15% pulley and dtbpv.
Screaming Devil!
Discussion Starter #16
Thanks guys!:thumbup:
Well it went with ups and downs,that's for sure!
But the experience is great,learned alot!:thumbup:
I would like to thank the Bentley manual:w00t:,my girl(patience),MT,my tools!
Screaming Devil!
Discussion Starter #19
Booked at 1320 for the 20'th of july!
Getting some parts,and getting a health check done.
The parts im picking up are not being installed 'yet'.
The package is not finished,i have a head-janspeed-clutch-chargecooler.
Pieces missing are a cam-injectors.
Tom.
1 - 20 of 262 Posts
