Hi guys just joined up, we currently have two minis R55 Cooper D clubman & R58 FJCW Coupe N14 engine
I’ve just changed the water pump, crossover pipe and revised thermostat housing and wiring (all genuine mini) as the coupe would get hot and be running cooling fan even on short journeys and we’d have not heat coming out of the heater.
It’s now all installed and running fine no leaks, no air in system (that I know of) but the lower rad pipe doesn’t seem to be getting hot, only done a short test trip, but been sat on drive for twenty minutes with heater on full heat speed 1 and still not hot, what temperature do these new thermostat open at? and how does the cooling system work on later minis? I’ve got Prestone coolant in mixed 50/50 with deionised water. We now get hot air coming from heater but no cooling fan after short journey so everything seems ok, cooling fan does work if AC turned on.
Cheers
Andy
Cheers
Andy
