1 - 8 of 8 Posts
So I got my r53 a couple of months back,so far I did the exhaust (top gear resonated cat back)
And a few other bits like an m7 strut brace and airtec induction kit and some Union Jack tail lights.
Next on the list is some coilovers,
I went with tein as I've used them in the past on civics and skylines and always found them to be good.
I got new top mounts so I thought I'd be good to go without the ball ache of stripping down the old struts but it turns out I need the 2 washers that go under the front top mounts as well so now I'll also have to buy some spring compressors small enough to strip the old ones but hopefully I can find some by the weekend.
Sent from my SM-F711B using Tapatalk
2006 cooper S 221bhp
I’ve got teins on my R53 and I love them, just need to stiffen up the rebound a bit on them though
I like them so much that I’ve just bought a set for my R56 too
i got some spring compressors off Amazon cheap, about £12 iirc, do the job nicely
Discussion Starter · #3 · (Edited)
Yeah,I got some cheap ones from amazon but they are too big,they won't compress the coils enough and I can't undo the top nut even with a big breaker bar
Edit,
I just took the struts to a local garage ,in probably less than 5 minutes and 5 quid(big hydraulic spring compressor and air gun) so I'm good to go
Discussion Starter · #4 ·
Anyway,
I decided to give the project silver top mounts a try, (why couldn't they make green ones) packed them with grease.
They come with a stepped nut to go inside but it's not a locking nut so I put the tein nut on the top to make sure it won't work itself loose.
You’ll defiantly have to report back how you get on with them with the teins, I’ve got a set of to fit to mine at some point
Discussion Starter · #6 ·
I will,
I must admit that I'm a bit worried about the noise they might make and also the longevity compared with standard mounts but I do really want to try them out
Discussion Starter · #7 · (Edited)
Fitted today, no nasty clonks, a slight bit more road noise compared to rubber mounts but not really too noticeable,
The teins as I expected ride excellent
Discussion Starter · #8 · (Edited)
So it's been a few weeks,
Added some kavs 11.5mm spacers so I have scope to wind the front coilovers down a bit more if I fancy it also wheel stud conversion,
So far so good, teins ride pretty well,silver project top mounts still quiet even if a bit harsh on pot holes,
Also audi tt gear gaiter and new gear knob
1 - 8 of 8 Posts
