401 - 420 of 486 Posts
Bob’s your uncle
Discussion Starter · #401 ·
Ah, JKo, you and your Baguette Extremes. I've already got a rear-engined car.
The Suzuki is a left field choice, especially in right hand drive. I suspect that I might not fit behind that rather odd steering wheel. Keep 'em coming.
Bob’s your uncle
Discussion Starter · #407 ·
Drinking coffee, enjoying the sunshine, looking at parts, admiring the garage, removing spacers ... I didn't cop much of a feel of your new knob though Micke even if it looks good. That was an oversight on my part.
Bob’s your uncle
Discussion Starter · #408 ·
Trying to stay on top of the maintenance: I've cleaned the interior, including the leather parts of the seats (it all smells better), topped up the oil (looks like a leaking valve cover gasket), topped up the power steering fluid, washed the engine bay, and touched up 'some' stone chips. Both doors are growing rust on the leading edge lower corners, and rust is bubbling up under the rear lights and boot handle. Bugger old cars.
Mr. White Shoes
Maybe soon you'll have another chance? :cool:
Some few more items on the to-do list and it'll be ready for the summer. And I see a road trip for 2021 to get the rest of things sorted out :D
Bob’s your uncle
Discussion Starter · #414 ·
I'm looking froward to getting BRB back as soon as the mrs gets her GTI back with 4x new pistons (next week maybe?).
I can then switch to summer mode (Sparco, Federals) for the track day on the 7th June.
Bob’s your uncle
Discussion Starter · #415 ·
Micke and DoubleP swung by for a some valuable 'carage time', a sauna, some BBQ ribs and some very sensible drinking: becausetrackday on Saturday.
We managed to fit the Whiteline rARB to Micke's machine in a couple of hours (not too bad), and we fitted a new coolant expansion tank (just in time from Amazon.de) and a power steering fluid tank sealing ring to my car, as well as the Sparco seat; just in time for the first trackday of the season on Sunday with the BTCF at Alastaro.
Bob’s your uncle
Discussion Starter · #416 ·
Is there any experience on the forum of the e45 master cylinder conversion? I needed to brake far too early at Alastaro, and I don't want to spend a shitload on new discs and pads if I'm still not going to stop.
Bob’s your uncle
Discussion Starter · #419 ·
My pedal has been good, but now - despite much bleeding - it's gone soft, so I'm wondering what the problem is (assuming it's not just worn discs). I suppose I'll need to replace the discs and pads anyway...
can be a mix of worn pads and/or discs, if the pads are worn you could try and wind the pistons back (or push) and chock any remaining gap, with pistons back this will reduce likelihood of trapped air, and of course a computer bleed helps, likewise if all new linings are fitted sometimes I takes use for the pedal to come, also check the rear slides aren't binding (corrosion crush) perhaps, or the cables/links holding off the stops....
