1 - 13 of 13 Posts
I’m swapping nasty cracked OEM front wishbone rear bushes with powerflex ones.
I know the sub frame has to come out for an easy install of these, are there any other easy suspension/handling upgrades than can be done while the sub frame is out?
This is on my 'to do' list...imho, i think once you've gone to the effort of dropping, it get the grinder and get rid of any rust anywhere. use POR15 or similar to repaint. Replace every bush, replace inner ball joints, inspect rack and retorque all fasteners, and if it was me, i'd replace the PAS pipes for good measure. Remove PAS pump and open it up, and clean the carbon from inside, and if it's showing any significant wear, repair or replace.
Once it goes back in, it will be better than new and hopefully hassle free for the forseeable.
1 - 13 of 13 Posts
