1 - 20 of 71 Posts
Don't know how accurate this is but a good reference none the less.
http://www.mini-madness.com/ProductImages/engine/Cylinder-head.jpg
Came across these on the net and thought it'd be a good idea to stick it in one place.
I can't vouch for the authenticity but looks to be a worthwhile difference if you are considering tuning a JCW car and you can get it reasonably priced.
Don't know how it can be a moot point really. The best heads flow more at high lift.
All the stats I've found seem to measure at 0.4 or 0.45. Your own TPR2 spec quotes a max lift of 0.41 int & 4 exh
Here's what I've found.. I've calculated the %age flow increase over stock from the numbers published to give some comparison..
JCW
Int 3.8% @ 0.4 Exh 4% @ 0.4
MiniMadness
Int 22% @ 0.4 Exh 33% @ 0.4
CNCHeads
Int 14.3% @ 0.45 Exh 36.5% @ 0.45
CHR Racing
Int 25.7% @ 0.45 Exh 34% @ 0.45
Sabre Heads
Int 11.4%, Exh 18%
MiniMania
Int 9% @ 0.4, Exh 25% @ 0.4
Can't find any stats for a Thumper head though. Can you share?
Waiting on RMW and Thumper stats - eViL
It is good as far as testing the MM head vs the Cos head and the JCW. It does show a lot of good info.
Thumper
Discussion Starter · #5 ·
Quite surprised on the improvement of the jcw head over stock.
Do they still make the Cosworth head?
no........
our exhaust flow before the extra work we do now flowed 188cfm on the bench....... to compare so you get the same type of numbers a stock one made 106cfm
Discussion Starter · #8 ·
Pics of JCW head vs Stock
Discussion Starter · #10 ·
No probs bud. Trying best I can to help out.
MT's Naughty Boy
Thumper
Mike, have you got the inlet and exhaust flow data for a TPR-2?
no........
Jan, the RMW Head flows more now than it used to? Impressive. How much more?
Dead One
Data..?? most are up to .500" or .550" when cams are under .500" it really is a mute point??
Thumper
JCW
MiniMadness
CNCHeads
CHR Racing
Sabre Heads
Int 11.4%, Exh 18%
MiniMania
So buying a jcw head, getting built with better valves and rockers, with a nice aggressive cam could be quite good bang for buck potentially?
Yes the JCW is bennificial power builder. As long as the Price is good, added a good camshaft and rock. No need to upgrade the valves, unless you mean increasing the size?? Yes
Thumper
PS: Scraggles.. those spec are do to spring specs NOT air flow.IF you notice the TPR2r will carry cams to .500" and more.
Tpr
I just wanna know which head will add more bhp and won't crack. I was told and head bigger ported that the jcw with damage my engine.
Joe
Farmer boy!
Thumper
Tpr
Yeah i did mean bigger valves.
1 - 20 of 71 Posts
