1 - 13 of 13 Posts
Hi all
So I've had my R53 for about a year and a bit now. Finally got a series of good mods done. More to come along with some details. But here is the mod list and pictures.
Enjoy
Mod List:
17% Pulley
Colder Plugs
Orranje Stealth Intake
GRS Motorsport Intercooler
Milltek Cat Back
Janspeed Manifold
Tom Cat
Front Superflex Wishbone Bushes
FX400 clutch
Lightweight Flywheel
Quaife LSD
Pagid Drilled and Grooved Front Discs
New OEM Rear Discs
Front R56 Calipers
EBC Yellow Stuff Brake Pads (all round)
HEL Brake Lines
Powerflex Lower Engine Mount
Team Dynamics Monza R 17"
Neuton NT5000 205/45/17
Administrator
Mod List:
17% Pulley
Colder Plugs
Milltek Cat Back
Janspeed Manifold
Tom Cat
FX400 clutch
Quaife LSD
New OEM Rear Discs
Front R56 Calipers
HEL Brake Lines
Those are some very nice mods!
Are you on standard suspension?
At the moment it is on stock suspension. Once funds are all good, I'll be putting on some KW XTA's on there. In the mean time I'll be doing more subtle interior mods. Post suspension, cam and injectors will most likely be on the cards
Must be pretty fun on track with all the mods you've done so far :thumbup1:
I'll be keeping an eye on this cos the engine/gearbox mods you've done so far are what I'll be wanting soon :lurk5:
The clutch is pretty easy to get used to on the street. Once you start doing hard pulls you will feel how strong the clutch is. It takes the gear and power without flinching. The reduced flywheel weight also means acceleration is greatly increased as there is less mass to gather inertia. It has a very aggressive sound once the engine reaches above 4,000rpm. I can probably upload a video of it. What are your plans?
The LSD is a god send if you like to drive a bit mad ;) Make sure you get the Motorsport edition IC. What exhaust do you have atm? The manifold will make it f'ing loud (coming from a non res miltek). What brake & suspension setup you got?
Discussion Starter #13
i was just reading through your spec and noticed you run neuton tyres, whats your thoughts on these?
The neuton's are great in the dry and warm. Wet not so great, but my car lives in storage in the winter
1 - 13 of 13 Posts
