They will most likely have some sort of splitter/diffuser up front as well to balance it out/counteract it
Looks, we tried every combination of things on the MT Time Attack car. It went a lot faster when we removed the lot and fitted the normal S spoiler back and removed all the splitters etc.
For a diffuser to work it needs to link up the whole floor. The only thing the rear one will do is possibly reduce some rear lift at high speed on the straights, however the mini probably isn't going fast enough for this to be an issue. A few tactical holes in the top of the rear bumper will probably achieve the same.
Simple fact is the mini is never going to go fast enough to make any areo work.
You're better off looking at mechanical grip and set up. To give you an indication most race teams will have an extensive data set of tyre temps, track temps, tyre pressures, suspension changes (spring rates, damper settings, arb settings). All of these will be looked at, checked and changed throughout race and test meetings.
To give you an idea even for some amateur racing where changes are allowed teams will turn up with three of four different tyres, different springs for the dampers, remove arb's for the wet etc.
People wonder why their car doesn't feel great on some track days or some days, well if it was all set up on a nice warm summer day and you have a 10c variance in road / track temp the car is going to show you it when you have opted for a suspension system that can communicate that.
