Ok, thanks...
Anyway, so I did the rocker cover gasket and that isn't leaking any more. Got my garage to do the oil filter and cooler gaskets so that's not leaking any more. Got it all cleaned up and had a look a few days later. The water pipes are weeping where they clamp onto the oil cooler so I'll reseal them properly so that's easy. However, there's oil everywhere again. This time I noticed it was green and stinks and on the rear of the right side. Hmm... The power steering pipes were oily so cleaned them off and came back a couple of days later to find them oily again and so is the bottom of the resevoir. I've ordered a new resevoir as it's piss cheap and will cut and seal the pipes. If that doesn't fix it, I'll change the pipes. I'm hoping it's just that dripping onto the driveshaft and spitting everywhere, otherwise it's the gearbox leaking form the driveshaft seal I reckon, although they are 'new'. I presume the gearbox oil is greenish and equally smelly as they ususally are?
I decided the flat panel filter in the standard airbox was sluggish so bought the correct fitting Ramair filter, unlike the Previous Owner, and it felt far better so have stuck with that. Also discovered during the rocker gasket drama that the intake pipe was split. Badly... Temp fixed with superglue until I got a silicone one on there and now all good. Helped the running a lot , but still does that engine faltering at idle thing occasionally. Took plugs out (new recently) and noticed number 1 was quite badly deposited on- black and white bits. Not good. Rest were normal. Cleaned up all and works good again. Did cold compression test and all at 70-75psi. Will test warm when I get the chance. At least they're even as I've been suspecting shagged rings due to the plug and the oil burning. 1000 miles before I'd put a botle of Liquid Moly Engine Restorer in to soften up the valve guide oil seals and help the oil filter housing leaks until I could get it done and blow me but it worked! Not sure if the valve seals are totally sorted but I'll pull the plugs again in a 1000 miles or so, but the oil use has definitely markedly reduced. At some point I'll Seafoam the rings and intake (got the 2 bottle soak the rings and add to oil and intake spray kit. Neighbours will love it...
Tyres getting low now so I've got to take the plunge and get the Team Dynamics Mini Pro wheels in 16" Gold with some decent All season tyres (it's a year round daily and I NEED to get to work in the snow). Going to be about £800 but I should recoup some on the sale of the 18s that are on there. Think they're R56 JCW wheels....????
Also managed during the summer to pick up an as new windblocker. This is the first of many, many convertibles I've had that really needs one and what a difference it makes! Fitted a replacement gearknob was mine was flaking too.
