321 - 323 of 323 Posts
2007 Mini Cooper S R56
Discussion Starter · #321 ·
Hello! How is the break in procedure going? Have you put much boost through it yet? Any new Dyno reports?
Hello mate. Break in is going sweet.... still some kms to reach the target. Car has been mapped for the new injectors cause afr was all over during start up. It was good only at steady low rpm throttle inputs. Final mapping soon.
Discussion Starter · #322 ·
One of the biggest issues in track use are high temperatures. Especially in big turbo projects you need every single possible way to keep them low without risking melting rocker cover. Aluminium CNC machined rocker cover can act as a heat sink to dissipate these temps. And in my project I will have a piece of mind that I am done once and for all with that weak part which causes so much problems. All the exhaust manifold has been wrapped with DEI to avoid heat exchange. Kakarakis performance made this beauty. Soon to be installed with AN-10 fittings and rooted back to stock connections.
Rat Garage works
Vaios
