you had the flywheel made? to take stock clutches as well as others?
I'm having some aluminium rebuildable flywheels designed, well I have had them designed, just need to make the decision on manufacture but they're expensive if only doing a few, they'll have renewable friction surface and ring gear, they'll take a stock clutch or any compatible with a stock flywheel, and will have the timing lock tool hole
Fwiw I'm also having a final drive conversion made in a few options plus a full straight cut dog engagement gear set, if you want to liven it up 😁
New for the N14, I already have them for the 53 Getrag.
