41 - 60 of 81 Posts
· Registered
Discussion Starter · #43 ·
Bloc, cylinders and head looks good to me, but I'm not an expert
What do you think ?
Only thing I will say, just for the science, I tried some liquid headgasket repair stuff.. it's shit, don't do it.
Automotive tire Yellow Line Wood Motor vehicle
Wood Gas Rectangle Font Metal
Rectangle Gas Automotive exterior Auto part Font
Vision care Goggles Eyewear Gas Personal protective equipment
Light Automotive tire Font Gas Circle
Automotive tire Light Motor vehicle Automotive engine gasket Audio equipment
Motor vehicle Automotive tire Audio equipment Gas Auto part
Just this lobe looking a bit weird..
Pen Office supplies Writing implement Writing instrument accessory Office equipment
· Registered
Discussion Starter · #46 ·
Ok quick question: Imagine the mini would make around 260~280HP, what Cluch/flywheel combo would be suitable without breaking the bank ?
I'm ok to get a 1000£ competition cluch if needed. But maybe I don't need to, and a more reasonable solution would be just as good for fast road use..
I don't plan on tracking the car, just hooning around in the nice B roads near where I live. And fuck around with the big expensive german cars on the autobahn 😅
· Premium Member
a) you probably don't need to fully forge it for the use
b) you won't likely be at 260-280 with a PH2
c) the stock clutch fitted to ideally a GTT flywheel using a Helix organic clutch, or cheaper is a TTV non rebuildable and slightly noisier flywheel (during start up)
Reactions: Shartak
· Registered
Discussion Starter · #48 ·
a) I 100% percent agree with you, I don't "need" to do it, but at this point, might as well ?
b) Damn I was pretty sure I saw some 260+ figures with Newman cam PH2 on here from back is the days ? what do you recon would do the trick in that regard ?
c) My stock cluch is bad shit gone. I was already considering the GTT Flywheel, seeing how praise it was on here, was also considering pairing with a FX400.
But if I can go cheaper with a more mainstream brand like Lux, Valeo or Hellix.. and get the job done the same way, might as well.
· Registered
Discussion Starter · #50 ·
The engine is fully ready for rebuild, I'll not bother with removing the crankshaft or the piston, I'll leave this to the experts.
From my point of view, even if the lower part of the piston is broken, the cylinder wall seems ok. I don't think I'll need to get it machined, but once again, I'll leave this to the pro.
Now seing this really make me question if a want everything forged.. Maybe just the pistons, just because I don't want to redo this engine ever again 😅
Automotive tire Tread Tire Rim Dishware
Automotive tire Wood Automotive wheel system Circle Auto part
Here is where the problem was all along, I have no idea how this happened..
Fluid Motor vehicle Liquid Automotive lighting Drinkware
Hood Automotive design Automotive tire Motor vehicle Automotive exterior
For ref, here is how it should look like
Bag Hood Cuisine Auto part Automotive exterior
Can't wait to start the mini again, it's like an itch in the back of my neck that I need to scratch for 3 years now !
· Registered
Discussion Starter · #51 ·
Has anyone tried to paint all the "dirty grey" bits like the SC horns, the intake manifold and the engine supports with VTH wrinkle engine paint ?
Footwear Tire Automotive tire Packaging and labeling Synthetic rubber
Hair Head Hand Eye Leg
I want to give it a try since everything is off the mini, and I always thought that these bare metal part were ugly when oxydized..
But I don't want to go the expensive way of powder coating it.
· Premium Member
Vapour or media blast?
· Premium Member
Reactions: Shartak
· Registered
View attachment 106190 View attachment 106191
There are some pics over on the NAM forum of the supercharger, horns, and other engine parts painted with VHT cast aluminum color ceramic engine paint that looked really good IMO. I’m thinking of refinishing my R56 trailing arms with it before the install.
I think the second pic in post #31 is an after shot: My guide to shaving a yak - North American Motoring
· Registered
Discussion Starter · #59 ·
I've made my mind on what I want to do with the engine.
Full rebuild is being booked, with forged piston, ported BVH, agressive cam (I don't know what for now), 550cc injectors and E85 remap. also got the Airtec oil cooler and a LSD on the way.
Now I've found a good deal on a CompetitionClutch kit, but I don't know if I should go for the stage 2 or 3:
Assuming the car will make 250+hp, what do you reccon ? I'm ok with both since I can have them at the same price, but I feel like the stage 2 may be a littke weak..
41 - 60 of 81 Posts
