ScanGauge II - 10% off!
45848 Views 179 Replies 47 Participants Last post by  Stampers
SCA001 ScangaugeII
ScangaugeII is a highly versatile and simple to operate car computer, compatible with the MINI's OBD2 protocols.
Features
ScanGaugeII - The 3-in-one Automotive Computer with XGauge
The ScanGaugeII is an extremely compact automotive computer designed to read and display information about your MINI in real time.
Simply connect the ScanGaugeII to your MINI through it's OBDII port using the included cable, turn the ignition key and the ScanGaugeII automatically connects to your cars internal computer - it's that simple.
Trip Computer
Automatically tracks four sets of trip data - Each with 11 individually stored parameters.
  • Maximum Speed
  • Average Speed
  • Maximum Coolant Temperature
  • Maximum RPM
  • Driving Time
  • Driving Distance
  • Fuel Used
  • Trip Fuel Economy
  • Distance to Empty
  • Time to Empty
  • Fuel to Empty
Digital Gauges
Display 4 gauges at a time from the 12 built-in digital gauges. the information is presented in Real-time!
  • Fuel Economy
  • Fuel Rate
  • Battery Voltage
  • Coolant Temperature
  • Intake Air Temperature
  • Engine Speed (RPM)
  • Vehicle speed (MPH)
  • Manifold Pressure (not available on some vehicles)
  • Engine Load
  • Throttle Position
  • Ignition Timing
  • Open/Closed Loop
Scan Tool
The ScanGaugeII allows you to troubleshoot your own MINI, read error codes, and the conditions present when the error occurred. You can also turn off the “Check Engine” light and avoid those costly trips to the mechanic.
  • Reads Trouble Codes
  • Reads conditions that set the Trouble Code
  • Clears Trouble Codes
  • Turns off the "Check Engine" light
  • Tells you when vehicle is "Ready" to pass OBDII testing
  • Make and store up to 10 rewritable special codes to send to the vehicle computer
MORE!
In additional the features listed above, the ScanGaugeII also includes these features:
Easy to Operate
  • Simple on-screen operation
  • 4 menu driven soft keys
  • User settable update rate (Slow, Normal and Fast)
  • A HOME key to quickly return to the start screen
User Settable Backlight Display Color
  • 7 Standard screen colors and a custom setting with 63 possible colors.
  • Backlight for night use
  • Both display and keys backlit
  • User settable Off, Low and High
  • Big display - 50% larger than the original ScanGauge
Automatic Power Control
  • Automatic delayed power-down after engine shutoff
  • Automatic power-up when engine is started
  • Manual power-up with delayed power-down via HOME key
Non-Volatile memory
(stored information is not lost when disconnected)
  • User settings automatically saved
  • Up to 10 user commands can be stored and recalled
  • Today, Yesterday and Tank Trip data automatically saved
  • Vehicle settings automatically saved
  • Easy Installation - no Tools Required!
Cable detachable at the ScanGauge II. Can be connected on the back or side.
  • Easily move from vehicle to vehicle
  • Compact Size - just 4.8"W x 1.5"H x 1"D
In short, I couldn't live without my ScanGauge now for telling me useful information about my inlet temps and importantly being able to delete annoying emissions codes that light up my dash.
Mini Torque members can now get 10% off the RRP of the ScanGauge II from MT approved supplier UKOBD by using the discount code MTDC01 when paying to get it for the special price of £118.50 including VAT & Delivery to a mainland UK address.
To purchase yours now, visit: UKOBD Ltd. :: specialists in automotive on-board diagnostic tools
1 - 20 of 180 Posts
I couldn't live without it!
When I cross that line i like to know what the temps are.
Worth every penny. It's cheap and easy to install.
3
Pics of SGII in various MINI's:
G
I want to know a few things though??
Can the scangauge tell me if my car is pinking?
I always worry about thrashing my car before its warmed up, so make sure its had a good drive before I do so and that im 100% sure its warmed up, what oil temp would be ok?
Also, what IAT is it unsafe to use high revs or WOT?
I believe timing is pulled when IAT's go over 50c ;)
G
Thanks! So thats when you start to lose power? Is it still ok to use high revs as the timing is being pulled so protecting itself? Or still not a good idea?
Hi revs are fine just don't do it for 20 mins some members do ::popcorn:: you all temps will start to creep up then.
When we run on the strip it goes to 7-7.5K before changing gear and we cross the line in 4th.
Some go to 5th ::popcorn::
G
You change at 7.5k? wow, is your limiter raised Jove?
So if your car was idling and had a IAT of 50c, youd still take it up the strip? What kind of IAT temp would make you let off and start cruising to try and lower them? (obvisouly not on the strip)
Yes it's been remapped.
Temps on Sunday where hign...
The last run i did with Paul after burn out temps where are 50c crossed the line at 72c So i knew then i had to stop. I could have gone and run again but the temps would have been so hi i wouldn't have improved on ET or MPH.
I don't really do hi speed runs it's normally a short burst then cruise.
Its not too bad for me though as my oil temps could run at 160 deg C with no issues. None of you lot could do that:D
G
2. rob
ive wanted one of these for ages thanks for the group buy (if we can get 5) i know 2 others that want one...
G
Put me down as a defo mate! I really want to be able to learn more about what my car is doing as i drive it! lol
Alex
G
It will probably persuade you to buy a GRS I/C lol
1.George
2.Rob
3.MiniPetrolHead (Alex)
1.George
2.Rob
I think Alex has a GRS IC now ;)
Anyone else for a ScanGauge?
G
bigshow, Emily and Sef was after one!
I know but I think they're getting a price through their own forum
Ill put my hands up for one depending on price as ive spend a small fortune ont he car recently
1 - 20 of 180 Posts
