Glad the coilovers didn't give you an serious grief, looking good!
Why would you not space the rears out of interest? I would be doing just for the look more than anything as the wheels tuck in a lot at the back as they are nowI'd leave the rears, or fit the 5's perhaps and 11's up front, it'll likely look better when you switch to 215/45 sometime if inclined
how do you find the lowering springs? Been toying with that, but keep hearing it’s too harsh. I’ve an R53 too, it’s my daily and only do around 5-10 miles a dayFirst major job was fitting some 30mm lowering springs. After the faff I had with the coilovers I wanted to just go for an easier option an as its a daily Il
I think the springs are good, wouldn't go any lower than 30mm with them though. It's definitely firmer but still fine for daily use. I do 70 miles a day in my mini for work and it's fine! I've had coilovers before on a previous car and the springs are way comfier than them.how do you find the lowering springs? Been toying with that, but keep hearing it’s too harsh. I’ve an R53 too, it’s my daily and only do around 5-10 miles a day
Sounds ideal then, which ones did you go for?I think the springs are good, wouldn't go any lower than 30mm with them though. It's definitely firmer but still fine for daily use. I do 70 miles a day in my mini for work and it's fine! I've had coilovers before on a previous car and the springs are way comfier than them.
I just got some off ebay, not the cheapest one on there but they weren't too expensive, around £100 I thinkSounds ideal then, which ones did you go for?
