1 - 20 of 22 Posts
Just doing the rear wiper delete and the rear wiper is stuck onto the motor bad. I've wd40 the hell out of it and left it as others did this but still no.
Any suggestions ?
WD40 is quite useless when removing anything that is stuck. That said I don't think there's any lubricant that helps to remove a stuck wiper arm. I tried with a puller, but ended up using the hacksaw method...
I've heard success stories of drilling a hole (with a smallest drill bit you can find) on the arm right next to the motor axle to give some play between the parts. YMMV
It hurts for a few days... after that you will adjust.
Bling is good for the old boy. Sloshes be loving it!! :lol:
1 - 20 of 22 Posts
