1 - 10 of 10 Posts
Iv had a search and cant find anything.
One of the clips holding the rear belt line under the rear window has snapped. I have taken the belt line off to try and replace the clips.
I cant get these off because the windows in the way. An one have any luck removing these?
Cheers
From memory of stripping down a rear hatch, they clip into the panel but are a bitch to get out and usually break as they come out.
Cheers
Chris
I don't mind if they break because they are already snapped. I need to know how to get the new ones in as the windows in the way lol
The window isn't in the way, they clip on the outside of the window. You use a small pick to pull the old ones out and then push the new ones into place and then clip on the chrome strip again.
The window is in the way. The clips that are broken go through the body of the car and sit just below the window. When I try prize them up the clip hits the bottom of the window and doesn't allow the bit at the bottom that goes through the body to come out of the square hole. The clips on the actual belt line are not broken
I've had the same as you, just break the old clips out and the new ones pop in, once the clips are in just clip it to the belt line
I have same problem window in way, how did u get clips out and new ones in as u say window in the way????
Maybe break them out as suggested..? I have a couple of broken ones too that I'd need to replace.
1 - 10 of 10 Posts
