1 - 11 of 11 Posts
Has anyone got a link for one that definitely works for a R56? They always just seem to list for R53... unless they're the same?
Seen some have used needle nose pliers with varying success but if I can hold of the proper tool I might as well..
Cheers
Try this, the measurements for the pins are in the description to make sure.
Sent from my SM-A520F using Tapatalk
I have that, can't remember if I use it all on the 56 ones properly, basically on the 53 I take the pin end off and just use the winder to push the piston 1/4 turn at a time but with grips gently to turn the piston, fiddly doing it in bits but one gets it down to a bit of an art soon enough ?
I tried a universal kit which was rubbish so sent it back and bought a laser line tool. It worked very well and worth buying to save the messing around.
1 - 11 of 11 Posts
