R56 Retrofit Set JCW Sportbrakes coding ABS
163 Views 5 Replies 3 Participants Last post by  CarsOrBikes
hello, I changed the braking system on a Mini r56, a front and rear jcw braking kit was assembled, does anyone have done the update part on the ABS to increase braking power to work with the jcw system? because in the retrofit of the braking system of the jcw it speaks in programming
Automotive lighting Camera lens Camera accessory Cameras & optics Auto part
1 - 6 of 6 Posts
The coding is more to do with the DSC I think. It might make a small difference to the ABS but for normal day to day driving the difference would be negligible. I'd imagine you'd get a similar effect with upgraded pads.
I'm not saying it's not worth doing, but I wouldn't worry too much about it if it's not done immediately.
can be done with aftermarket diagnostic kit, Autologic and some Autel for example will do it via programming function if equipped with it
car being from day to day I feel it uncompensated so I think that configuration improves
if autel does i can get one since autel is easy way to code
it will need to be one that does programming not just coding, so Elite or Ultra, and in licence
1 - 6 of 6 Posts
