R53 wrx turbo conversion
1 reading
76K views 566 replies 35 participants last post by  Rob180bhp
#1 ·
It's started.....
Removed all the plastics and looking at the best position to mount the turbo
#2 · (Edited)
Looks like I'll take poeples advice and won't both twin charging and go straight to turbo only
Tommorws job is remove bumper and measure up for a front mount
And remove the down pipe and start cutting to make a turbo manifold using the old parts
My goals are not huge for now, get the turbo and intercooler fitted and working, aim for 15/18psi
#3 ·
Take a little look at the 1320 jobs, their turbo location looks the best, the location you have shown has been known to cause oil supply issues in the past.
Good luck, I think a turbo conversion should be quite easy for a lower power system. I often thought I just getting a turbo but I still think the R53 should be supercharged...
#8 ·
I am not sure, I have never really looked into it but I can tell you that over 10 years nearly all the turbos mounted there have failed. I believe most were oil related. However I can't give a good enough explanation to why. I believe that 1320 are currently making the most reliable conversions and if I was going to make one I would look towards them. Also with a little longer runner you will reduce some of the immediate heat which could have been part of the issue
Making a manifold and bolting a turbo is the easy part, and it will be good to see how you tackle this build but my only advice is look at those who are having success
