Hi guys
Really need some help as google isn't shedding much light on the issue.
So after having an issue with the battery I found a shallow pool of water under the battery when replacing it.
I done the obvious and dried out the boot completely before fitting the new battery. After I fitted the battery I sat in the boot while I had someone spray the back end of the mini down with a garden hose.... And this is where I realised it was getting in from the rear lights.
I took the rear lights out completely, cleaned around the seals and refitted and I still have the same issue. Is there a known fix for this or am I going to need to go all out and buy new lights? One is starting to go cloudy so I was considering replacing one any way.
