1 - 20 of 24 Posts
R53 Parts.
Mini Mania (fidenza) light weight flywheel. £150
Helix auto sport 4 pick clutch kit with organic drive plate. The 4 puck clutch could do with getting re surfaced otherwise I have a sub 100 mile organic drive plate to throw in too. £150
Janspeed Manifold and high flow cat. This has AFR sensor bung welded on. The flexi could do with being replaced but the cat is fine. £100 with the flexi needing replaced.
R53 Airbag reset tool. £20
Mocal Oil cooler with black braided lines. Oil cooler built in to the front crash bar. £80.
Poly bushed engine mount £20
Face lift super charger with 16k on from
New including a Kavs 17% pulley fitted. £150
Alloy header tank, needs cleaning up but that’s easily done £20
Full replacement brake line kit. Black coated lines with all stainless fittings. £100
Front slam panel with all rads. No cracks at all. £80.
FJCW R56 exhaust cat back with hangers
to suit an R53. £230.
R53 MFSW Facelift Steering wheel Airbag £165.
Front HK door cards £20 each with all grills.
Rear HK Panels £20 each.
Rear leather seats £80
Ferrari replica gauges £80.
R56 sideskirts to suit R53. £200.
I'll have the charger please,
I also have the full air con pump an lines.
Starter motor etc
Any other standard parts I could pull off the chassis anybody needs?
I don't suppose by any chance you have a JCW aero grill (upper)?
Do the side skirts come with everything required to fit on to my R53 too?
Tom
Discussion Starter #12
Tom
I do.. but the inside has been ground down to fit a front mount inter cooler piping years ago. It still looks the same on the front.
The side skirts come with everything other than new clips to fit to an R53 yes.
Discussion Starter #14
Picture attached. It’s been painted so no longer oem plastic.
Discussion Starter #15
I didn’t expect this amount of parts to get sold within 12 hrs I’m off out after work today to source mountains of card board an boxes.
I’ll get everything packaged up an you will all receive an email notification from the courier via email with tracking details.
Discussion Starter #18
Please don’t get butt hurt if you don’t respond and parts are sold.
You either Pay or you don’t Pay.
That means if you pay, I send. You receive.
No dibs, no holding anything. Cash is king.
Discussion Starter #19
Parts that are paid for are now packaged ready to be collected or dropped off.
I’m 1 day behind in getting these out, apologies.
You will all receive tracking information as soon as it’s book in the next few hours.
If the parcels are not too heavy to be dropped off I’ll do that tonight otherwise the courier will collect tomorrow.
Discussion Starter #20
All parcels dropped off. You should receive an email. They will be collected by 3pm tomorrow at the drop of shop and be with you within 24hrs later.
1 - 20 of 24 Posts
