1 - 7 of 7 Posts
Hello guys! Hoping to get some advise here :) I will try to keep it as short as possible but also mention all important info at the same time. Replaced parts are underlined.
Had my R53 (2003) for 5 years now, been replacing what soon feels like every component in the entire car, it came as no surprise to me when it suddenly lost drive on the way home from work one day. Dailying an R53 you kind of just drive around waiting for stuff like this to happen. I was pulling away in 1st gear when the car suddenly lost drive and engine revved up. Same symptom as if I would hold the clutch pedal down. Pedal felt normal but the car would not drive forward no matter what I did to the clutch or shifter. Gear shifter felt normal, gears would also go in as if the clutch was pressed down but even with the pedal up the clutch would not disengage and car would not drive.
Towed the car home and ordered a new slave cylinder as this was my first suspect without beeing able to look under the car. Replaced this, found that the brake line going to the slave cylinder was very rusty and even broke on disassembly so ordered and replaced this as well. Bled the slave cylinder properly and made sure it pushed the lever on the outside of the gearbox. Put the car back on the ground, hoping that I had found the cause to the problem. Tried the car, and it was working! Let it warm up, went for a 10-15 min test drive and still working. Then on the way home the exact same problem occured again... After maybe 30 minutes of driving. I was pulling away in 1st gear when it suddenly slipped out of gear and engine revved up. Gear stick would go in any gear but nothing happened when pressing or releasing the clutch pedal.
Towed it back home and decided to change the gearbox oil as I read that the gears are held in place by hydralic pressure. I had noticed some leakage from the drive shaft seals as well, so replaced the seals on both sides. When changning the oil only about 20cl came out, and almost 2 liters in (Redline MTL). Knowing this I felt pretty confident that I had found the real root cause of the problem. Put the car back down, let it warm up, went for a test run and everything seemed to be working. Went for a longer test run this time, slow driving in 1st and 2nd gear over speed bumps etc. Some high speed, going through every gear. Maybe 45 min test drive this time, everything worked and the car even took me back home. Then the day after, after about 15 minutes driving, the same thing happened again! This time when driving on the highway in 6th gear. Totally relaxed on 2,5K RPM, it just slipped out and engine revved up before I released the throttle and started rolling to the side. At this stage the car was rolling but no gears would work. Gear stick felt normal but the problem was the same as before. It behaves just as if the clutch would be working and you press it in, like the clutch is engaged. Then I towed the car back home and there it has been standing in shame for 3 months now.
I'm not in the need of a daily car right now so I haven't found the motivation to fix my beloved Mini until now. But I'm really hoping to get some pointers in the right directions from you guys and then find the motivation to get it back on the road! But at the moment I have no clue what the problem could be. Both times I felt so sure I had found the issue when the car was working after replacing those parts. Worth noting is that when the car was not working, it was 100% not working. It went from working perfectly to not at all. Not some re-occuring issue that the gears slipped out and then back in or anything. So I find it very strange that the car would go back to "working" both times after obviously replacing the wrong parts. Or at least haven't found the root cause yet.
Like the first time I only lifted the car, changed slave cylinder, brake line, bled the system and put it back down. Result: Working again for 30 min.
2nd time I only lifted the car, emptied the transmission fluid, put new shaft seals in, put new fluid in (about 10x more than came out lol). Result: Working for 1 hr, broken day after.
Why would it work if I haven't found the problem yet? I still haven't opened the gearbox and would like it if I didn't have to. I can see the slave cylinder working when I press the clutch pedal. It's pushing the lever on the gearbox all the way in. So I don't think the problem is on the outside. What I haven't checked yet on the outside of the gearbox is the shift wires. Could faulty wires cause this? The problem is as if the clutch is broken, but the opposite. It's not stuck in gear, it's not able to engage any gear.
Please, very thankful for any advise!
Are your flywheel and clutch plate OK? Your symptoms seems to indicate a break in drive when the clutch pedal isn't being pushed. That doesn't point towards the gearbox, rather towards what connects the engine and gears, the clutch and flywheel.
Could there be an issue on either of the output shafts? If it's not a clutch issue and the gearbox appears to be working normally then there might be an issue with one of the driveshafts. I'm not familiar with the R53 but it's it possible for a driveshaft to pop out of the box slightly and lose drive?
the description also covers it jumping out of gear, which is a sign of internal box wear, and likely considering it had no oil in it for however long, or motor mounts shot potentially contributing along with cable/linkage state perhaps? Check the bushings on the cables and on the main linkage so you know throw isn't affected, and look at mount state....
if the car goes into gear without the clutch down it suggests the clutch has failed, or it simply wouldn't if you are already satisfied that the hydraulic side is functional, so it comes across like there might be more than one issue? Does it bite quite high normally?
gears aren't held in hydraulically but by detent springs in the synchro hubs,
if it's been run with no oil in it, imo just source another box and renew the clutch,
I had the same issue but i pushed in the clutch let out the pedal and it started engaging. I got out of the shop and started to push the pedal in and then back off to avoid smashing into the truck i had parked outside then it seemed as though the clutch was disengaged cause i could put it in gear while the motor was running and not pedal pushed in.
could this be the clutch having air in it pushing the slave far enough to disengage the clutch from the flywheel?
It is a brand new valeo clutch and single mass flywheel i just put in but i decided to replace the entire clutch cable with braided and am not sure i did it properly.
100% no, if there is air in the clutch system it will not disengage the clutch, exactly the opposite of your issue.
Your clutch isn't cable operated, so I am assuming you mean the hose.
Whether it was done correctly, obviously we can't comment on.
1 - 7 of 7 Posts
