21 - 40 of 48 Posts
That is where the oil filter housing goes. Engine & gearbox in then subframe.
I would put these on too ?....
Discussion Starter #22
Im thinking BC RM coilovers might get added to the list along with a Coolerworx gear lever, track/hillclimb/road car
I'd fit camber top mounts not camber joints, otherwise you'd need caster bushes to correct it and never be able to increase caster further should you wish,
then I'd take the gearbox back off and send it to me for a final drive conversion, or have one fitted to a BKD box if yours isn't one ;O)
Discussion Starter #24
Ok cool standard bushes it is,
Id love to send the gearbox off to many places for many things, but its rebuilt, quaife in and boxed up, filled with fluid now. pretty sure it was a BKE
(y)
They would be pretty decent for that, I used to have when I was planning on my car being used for sprints and hillclimbs. They are a bit hard for the road if your car is going to be mostly road I would look at other options.
Discussion Starter #29
Its as good as done.
Any advice on running in a new motor?
i was going to take it to 1320 and have it done on the rollers but thats been C19d
Im thinking up and down the rev range...make it work abit, but below 4k for the first 200miles, no steady running or idleing, then run it hard
I'd just keep the rpm varied between 2-4 with some medium but varied load during the first hour which would help rings, then do similar avoiding full throttle but letting the engine rev freely and by another 50-100rpm/50-100 miles or something until you're at the top. It'll need some load to seat rings but they might take some time, but also lighter load engine spinning at varied rpm for reasonable distance, there's no rush, I wouldn't use full throttle too soon or max rpm.
Discussion Starter #32
Had a go at a list of whats been done...sure theres plenty more
Strip short motor and report
Bores checked and honed
New crankshaft balanced
Works Head striped and inspected
Head bolt conversion
Timing chain kit
New rockers shafts
Full set of rockers
Newman Cam
Alloy radiator reservoir
Alloy radiator
New alternator
CD multichanger converted to USB
New AC pump
New AC condenser
Silicon hoses
Piper air filter in works box
Rear wiper delete
Bosche 550cc injectors
BC RM Coilovers
New wheel bearings
New ball joints
12mm wheel spacers
Collerworkx Pro short shifter
New gear cables
Vibra technics race engine mount
Powerflex gear box mount
Powerflex lower engine mount
All new pulleys
Rebuilt 6sd gearbox
Quaife LSD
GTT aluminium flywheel
17% Pulley
Airtek Intercooler
Cooler Plugs
1320 Base Map
BMW release bearing
Organic clutch plate
Orranje PTFE Supercharger gasket
Serviced Teflon super charger
Works exhaust centre silencer delete
Reconditioned 16 valves, recut and lapped
Surface head -0.006”
Set piston ring gaps
Machine exhaust manifold to match head
Wossner Pistons
PEC Steel Rods
Race big end bearings
Race Main bearings
Oil Pump
Chain tensioner
CV Boots
Balance rotating assembly
Front subframe removed cleaned and black poly bushed
Nitrac front discs
PBS Pads
Anthracite interior
Matte black head light rings
Smoked led rear lights
Discussion Starter #33
Well that didnt go to plan...
Everything looked ok, oil pressure was fine, temp in and out of the radiator was fine, so I went for a drive...all looked great untill I parked up at the shops...a casual glance over the shoulder as I went into the shop...big puddle of coolant on the deck...fuk sake
Started it up a bit later...nice bit of white smoke and the sweet smell of anti freeze
The radiator was stone cold, I think the cooling system got air locked, who knows.
Hopefully just a head gasket and not the block or head...back to the spanners...
Water pump was the only thing I didnt do
Discussion Starter #39
Cheers, Im not planning on doing it straight away, Ill see what the damage is first, if the front has to come off the car then Ill give you a shout
Discussion Starter #40
Ive done a leak down test and all cylinders look fine
Did a pressure test on the cooling system to 15psi ish with no bubbles in the coolant and the pressue held
All the plugs looked the same
No gunk in the oil
Got one of those block tester kits that check the coolant for hydrocarbons on its way, maybe that will show something
With no indication other than an amount of white smoke and a sort of sweet smell from the exhaust, Im reluctant to start taking the head off.
All these tests were done with the car cold
The fuel in the car wasnt straight from the pump but from jerry cans...maybe that is an issue..
hmmmmmmmmmmmm
21 - 40 of 48 Posts
