1 - 20 of 70 Posts
After having a very nice and fully modded MINI Roadster for 4,5 years we needed a new project.
So just before Christmas 2016 I bought myself GP2 #0953. I'm now making a the topic on Torque as well...
11.500 km on the clock
I imported the car myself from Germany. Bought it at the MINI dealer Neumarkt around Nürnberg.
Begin 2017 I got the licence plate of the car.
First step:
Get it detailed!
Car is washed, clayed, polished, coated
For the coating they used 4 layers of Gyeon MOHS. The best coating you can get.
Before:
After:
Clouds in the engine cover:
Let the upgrading started!
Than the upgrade list:
Update on mods:
Technical:
OEM GP2 wheels with 5mm spacer Michelin Supersport 205/45/17
OZ ultraleggera 7x17 ET37 with 5mm spacer Yokohama AD8R 205/45/17
Intra RSA coilovers including camberplates
Alta 22mm rear swaybar
Hardrace camberlinks
Goodridge steel brake lines
Airtec large intercooler
Evolve heat coated Decat downpipe incl Akrapovic delete-R
Setrab oilcooler incl thermostat and oilpressure sensor
Powerflex front control arm bushings
NM shortshift unit
K&N inlay filter
Forge recirculation valve
Forge silicone noise generator delete pipe
Forge silicone intake hose kit
Forge intercooler reasonator delete hose
OS Giken superlock sper differential
OS Giken STR clutch with single mass flywheel
Bytetronik full custom software
Interior:
OEM MINI shiftlight
OEM MINI secret glovebox
OEM MINI Armrest
OEM MINI windows screens
OEM MINI multifunctional buttoms in steeringwheel
OEM MINI Cruisecontrol by Ben van Leeuwen
OEM MINI Recaro CS seats leather and alcantara
Schroth Racing Profi III 6H
Custom second generation carkit holder for iPhone 6S plus
P3 carunit
A2DP Music Streaming Adapter ViseeO Tune2Air
Scancauge II
Coolerworx shortshifter
Hertz MPK 165.3 compo set incl tweeters
Hertz HCP 5D amp
DD audio 6" subwoofer
Exterior:
OEM LED driving lights
OEM Blackline blinkers
OEM Blackline backlights
GP 0953 roof decal
Headlight rings painted in Thunder grey
Backlight rings painted in Thunder grey
Door lights theme “street legal go-kart” and “Hang on I want to try something”
To do:
Who knows what.... :thumbup:
Is the alpine upgrade still easily available ?
I'm looking for a roadster project and had narrowed my search to only hk equipped cars
No the alpine I found a set new in Germany... lucky me...
I had a quite modded Roadster before. But make sure you will get the HK option!
So first we installed:
Intrax RSA coilovers
Alta 22mm rear stabi
OEM shiftlight
MF Buttons
As you all love photo's:
Installed:
Soon more to come!
Next step, new upgrades on project GP2 #0953
Powerflex front bushes:
Also we installed Goodridge steel braking lines and used ATE super blue brakingoil
Before frontside
After frontside
Before backside:
After backside:
Soon more upgrades!
As my wife is this GP not using as daily...
New update:
Wiechers Clubsport
Later the seats and the harness!
New post: New mods....
We installed the Recaro CS in alcantara and the Schroth Racing PROFI III harness
As well the JCW carbon/leather shifter was installed.
OEM MINI storage net at the passenger foot compartment. Very handy for putting in a 12volt splitterblock during road-trips.
Next steps the Airtec intercooler, oil cooler, large Forge recirculation valve, MINI led driving lights are on the planning...
But anyway Project GP0953 update:
This day I didn't had a lot of time. So only installed the OEM secret glovebox. I need to glue the GP sticker back on it. Than the photo will follow
Also I took all the air hoses away as they will be change for the larger Forge ones
And very happy with the backplate in the boot.
I needed the cut a part out due to the rollbar but it full operational again. The side I will cover as well with the parts cut out!
Project GP0953 goes on.
Seats installed.
Floor trim around the cage.
Scancauge installed.
Solar screens installed.
P3 carunit installed.
Sticker tuning.....
Discussion Starter #11
And again a new day..
Project oilcooler was quite a job!
As we want to install a oilpressure sensor there was an extra connection on the adapterplate. This was really to close to the oil filter housing. So we needed to take something off.
And than it fits!
Also the 85 degrees thermostat needed to have a spot to connect
And when it finished it looks like this:
The smart watcher see as well a red Forge resonator delete. Also this is installed!
After this we could install the new Airtec intercooler
To have the oilcooler lines nicely fitted we needed to adapt the air brake ducts. As we have done this before we knew what to do.
Still to do:
Change also the other Forge noise generator delete
Connect the cables for the led driving lights
Connect oil pressure sensor to the P3 unit
Cruise control will be installed, error of the Recaro CS reprogrammed and change language to English.
Discussion Starter #12
So new update.
I went to Ben van Leeuwen in Holland. Ben van Leeuwen | It's all about Mini!
This place is know about their service for the classic MINI but over the last years the are also actively working with the new MINI's.
Biggest reason I went to them is to install cruise control in the GP2. A lot of people worldwide tried but didn't succeed. But son Tom knows what he is doing.
After 4 hours I had:
Update on language
Comfort closing on window passenger side
Code the Recaro's CS
Switch off notifications of no seatbelt use (due to Schroth harness)
Cruise control
Also my friend Rob was there with his GP2 to code his Recaro's CS so they were also proud they had 2 GP2 in their workshop.
If you are in Holland and want to see also their museum with very special classic go there!!!
This family has really MINI passion.
Discussion Starter #13
Small update from www.signmyride.co.uk
The new roofnumber arrived
Also a small version was ordered:
Also the OEM MINI privacy shades were installed
Extra button for the passenger was installed.
Both the door lights were updated:
Driver side:
Passenger side:
Discussion Starter #14
End of May we went on a trip with 27 MINI's from Holland Belgium and 1 from Norway.
8 days
7 countries
3.750 km
Partly the F1 circuit in Monaco
Classic Route de Monte-Carlo
A lot of other mountain roads
These were the ingredients for the trip
NewMINIclub goes Monte-Carlo
Me and my boy buckled up for Alle d'Huez
At the top of Alpe d'Huez
Top of Monaco
Also begin June I drove for ill and/or handicap children
Discussion Starter #15
Engine bay upgrade with Forge
For the Forge turbo inlet hose we took the one for a MINI R60 and upgrade this with the Revotec SST8K Hose Take off Kit for 8mm the connect the tube from the side.
Fits perfect!
Discussion Starter #18
As we love pictures:
Preparation for more power....
We started to install the clutch and LSD.
First finding. Little leakage on the gearbox. (With 18.000km on the Tacho).
Anyway surgery has started.
Discussion Starter #19
This is the actual stand of 28th of October 2017.
The GP2 is in the garage for fitting the clutch, LSD, M7 RAM Air Intake, Brakes, Oilchange, N18 fix...
When there is an update I will post here as well...
1 - 20 of 70 Posts
