1 - 20 of 30 Posts
Ā· Registered
Ā·
Aptly named as my R56 currently sounds like a steam train! šŸ™ˆ
I’ve been buying and selling cars long enough to know that you generally get what you pay for…
On this occasion, heart won against head by first round KO.
There were a couple issues on the test drive but I gambled and lost that these would be minor and offset by the heavily adjusted purchase price.
Fast forward a few months and she dies on me on the motorway in a glorious cloud of smoke!
After much umming and ahhhhing and conversation with a couple of members - I opt against junking her and get in contact with the wizard that is @CarsOrBikes
Tire Wheel Land vehicle Sky Cloud
Fast forward again to a gap opening up and she’s off to see the Wizard.
Any hopes of a ā€œquick fixā€ were put to bed early with this image of a nicely melted piston…
Automotive tire Liquid Automotive lighting Circle Astronomical object
Ā· Premium Member
Ā·
Well firstly, thanks for entrusting your car to me ;O)
It will be taken care of and hopefully come back to you better than before....
Reactions: jj10
Ā· Premium Member
Ā·
Is that an almost clear driveway at carsorbikes house?
might be time to get mine over for some little jobs!
that was an illusion šŸ˜‚
Wheel Car Tire Land vehicle Vehicle
Reactions: jj10
Ā· Premium Member
Ā·
so Jay's motor has a fairly big issue in number 2,
Gas Automotive tire Motor vehicle Auto part Machine
boom
Wood Machine tool Metalworking hand tool Machine Close-up
Reactions: Jimmy-Mac
Ā· Premium Member
Ā·
and as they do....
Shoe Light Green Blue Automotive tire
eat straight into the block
Automotive lighting Automotive tire Motor vehicle Hood Light
when deep enough to pool oil it ain't coming out with a hone that's for sure
.... or a re-bore !!
Tire Automotive tire Wheel Synthetic rubber Tread
actually hard to see here but there is really quite a significant negative peak to this flash through so it could be the block a no go,
we have to test machine it and see if it cleans at sleeve depth.... at the moment the machine shop are divided over that but will be trying it.... you can perhaps only just make out a small black line in the cavity which when looked at closely is actually a further peak, just unlucky that's all.
Reactions: Jimmy-Mac and jj10
Ā· Premium Member
Ā·
Before
Automotive engine gasket Audio equipment Auto part Gas Technology
After
Automotive tire Motor vehicle Rim Automotive exterior Engineering
During
Automotive tire Light Rim Font Synthetic rubber
Cleaner ;O)
Light Automotive tire Gas Engineering Auto part
Fashion accessory Service Tints and shades Electric blue Carmine
Before
Eye Helmet Automotive tire Wood Audio equipment
After
Automotive tire Automotive design Synthetic rubber Grey Rim
Ā· Premium Member
Ā·
just a last few awkward bits of carbon now removed, can wash this off and get the valves lapped in now,
Automotive tire Gas Composite material Auto part Automotive exterior
Bumper Gas Rim Automotive exterior Auto part
Human body Tints and shades Snout Auto part Circle
Automotive tire Automotive lighting Gas Audio equipment Automotive wheel system
Reactions: jj10
Ā· Premium Member
Ā·
Automotive tire Engineering Font Machine Auto part
Wood Table Automotive tire Musical instrument Flooring
Automotive tire Wood Tableware Rim Bicycle part
Automotive tire Automotive wheel system Gas Engineering Composite material
Ā· Premium Member
Ā·
this has been quiet for a long time....
block has been away with the aim of trying to save it....
which I'm pleased to say we have done ;O)
Automotive engine gasket Gas Audio equipment Auto part Composite material
I've had these sleeved before but this one was a bit more of a challenge for the shop, in the bore damage shown above was a negative peak that unfortunately took it outside the diameter of the sleeves we've used previously
it's pretty clear here
Tire Automotive tire Blue Tread Wheel
it could potentially have been filled and machined prior to sleeving but we didn't really want to do that, instead there was a hunt around for a suitable sleeve that they thought could be used
the machine shop found one which was huge really, so it had to be significantly altered, turning it into something that could be made to work
Household hardware Composite material Gas Nickel Auto part
Waste containment Waste container Cylinder Drinkware Table
next came more test machining just to see what block material we were left with, sorry no pics of this but if you saw them you'd probably all say the block was scrap.... it nearly was
after many weeks eventually they got this to a point where they called and said they were of the opinion they could in fact quite likely make it work, where previously the guys were divided on its potential, basically the result being the sleeve and block had to be modified further which has resulted in the sleeve actually touching those of the adjacent cylinders right at the very top only, kind of machining a step in the now rather thin base casting, it's done in such a way that the sleeve top isn't loading the adjacent one so much as having a nice interference apparently, you can see it in the top pic if you enlarge it compared to cylinders 3/4 that retains a gap
clearer here, 1/2, 2/3, vs 3/4, you can see the difference in sleeve thickness at the very top, slightly less below though, as they had to retain block material wherever they could, I'm sure most would have written this off
Tableware Vision care Eyewear Dishware Eye glass accessory
Automotive tire Automotive design Line Material property Alloy wheel
Automotive tire Light Automotive design Rim Alloy wheel
and now we're in possession of a nicely (luckily) saved N14 original block which is still in standard size 'just', so has some longevity as well as getting to go again now, those slightly dark areas are nothing much and will clean up by hand, just very slightly low ring turn points the honing blades wouldn't quite get, plenty come out like this, the main thing to note is that these are done to measured sizes, most you might get to see probably aren't
we did discuss changing the block of course but Jay's preference was to retain his original if he could, for a while it didn't look promising, but somewhat of a gamble later he has what he asked for ;O)
so now with some other bits out of the way or set aside we can look at finally doing something progressive with this car, now firmly amongst the 'long termers' šŸ˜‚
first I wanted to get it moved back out of 'pending corner'....
Wheel Tire Car Vehicle Hood
into a priority spot closer to the motor about to be assembled
Tire Wheel Car Vehicle Window
Car Automotive parking light Vehicle Land vehicle Tire
then onto cleaning stuff up a bit and sorting some things out....
Reactions: GC1980
Ā· Premium Member
Ā·
basically parts get washed off again, threads, galleries, cleaning bearing journals, blow it off/out, repeat etc.
not every motor gets its exterior corrosion cleaned up much if at all but the built up oil deposits get removed and most of the internal staining/varnish goes....
Blue Automotive tire Automotive exterior Gas Bumper
Automotive tire Motor vehicle Bicycle part Wood Bumper
bolts run through the threads making sure they're free and all seat the same, to a 'stop', even though they never need to hit a stop we don't want roughness or obstruction, these only have an initial torque of 30nm for example, a rough thread or similar factors can put a 15 degree difference between one 30nm click out or a true 30nm one, the second stage is a 150deg turn, so an inaccurate 30 can mean a false 150 equating to a 135.... there's more to Seany's way but food for thought perhaps.
Wood Tool Engineering Gas Toolroom
clean up the crank a bit more, this was cleaned up by machine a bit (termed polished),
Light Hood Bumper Automotive tire Wood
we need a spare piston as one ain't fit for purposešŸ˜‚
Kitchen appliance Blue Green Gas Auto part
this isn't part of this job, but out of curiosity I looked at the weights of the remaining three pistons which differed by around 2.6g, out of the others I could find two sets ~1g apart. I couldn't find one any nearer the weight of the originals, and going through wear comparisons found that making a new set up, swapping some stuff around, I could get a set to within 0.6g,
Automotive tire Wood Cylinder Gas Auto part
so this is what's going in, sure still some wear but almost the same as the originals, comparable size, these just have some exhaust valve witness marks which I've cleaned a bit, the outcome can only be better than before,
Motor vehicle Automotive tire Automotive lighting Automotive design Automotive exterior
the rods I'm not messing with which makes the above somewhat of a waste of time, as those have a weight difference overall, so I've just put the lightest piston with the heaviest rod, as I said this stuff isn't part of this particular job, I was just free to do what I want so chose to look at it a bit,
Automotive tire Bicycle part Bicycle chain Gas Crankset
Automotive tire Motor vehicle Wood Automotive exterior Automotive wheel system
and they're in....
Automotive tire Automotive lighting Motor vehicle Hood Automotive design
slimy job thatšŸ˜‚
1 - 20 of 30 Posts
