FYI the roof was professionally cleaned treated/waterproofed in the early summer, it has had a cat sleeping on it regularly since though as you know!
the fan was fine the day before you got the car as sean checked it on the diagnostics, might save you a job
numberplates, yes, they probably look extra scabby now its so much cleaner
Cheers Jim, handy to know. I guess it doesnt last forever and with the recent deluges whilst its staying watertight it does seem to be absorbing rather than expelling. Gonna give Gtechniq smart fabric a go at some point I think.
Also really good to know about the fan, I recall you saying Sean popped it on the diag so makes sense. The thing does run sweet as a nut, starts first time, everytime all weathers, really a great little car.
Number plates....pretty much something I do on any older car I buy unless they are already pretty recent as its amazing how much it freshens a car up.
As is the usual thing you go looking for problems, inevitably you find one.....seems the boot has a slight leak on the drivers side.....I thought after all the rain id just check the usual areas.....rear footwells...fine......under rear seats....fine.....under boot carpet....slightly damp. Is weird as the carpet is dry, just damp underneath...and its not gotten anywhere near the toolbox area (as in dry under the pump and gunk) so it cant be bad but the jack is quite corroded and moisture seems to have gotten to the tyre pump so guess its probably been like it a while on and off. Im thinking either the seal is letting by slightly or it might be coming in through the handle gasket or tail lamp.....time will tell I suppose. Definitely not the hood as far as I can tell.
Might start seeing if I can adjust the tailgate latches at all so they close a bit tighter and go from there 👍👍
