1 - 6 of 6 Posts
That's you, that is.
So I got around to sorting my new manifold and I noticed that the stock mani has a much deeper boss for the pre-cat O2 sensor than the new one. On the new mani, both the pre-cat bosses are shallow enough to let the entire sensor head stick out into the flow, which I’m sure I read somewhere is a Bad Thing.
Should I be adding a spacer here, both for the narrowband sensor and for the wideband that I’ll eventually fit?
a wideband sensor would be vulnerable, they need a 1" bung.
I have 1/2" in my aftermarket manifold for the stock sensor fwiw, but the stock pipe is 1" pre-cat and 1/4" perhaps post cat or thereabouts, other aftermarket pipes seem to vary,
Discussion Starter · #5 ·
Both bungs in the scorpion are 1/4 inch, so should I buy a 3/4” spacer for the stock pre-cat sensor to make it the same as the stock manifold or leave it as-is?
1 - 6 of 6 Posts
