1 - 5 of 5 Posts
the oil pressure light keeps coming on ive checked the oil level and its fine its been happening a few times since I did oil filter change about 1000 miles ago im wandering if its the oil filter I got it from euro parts forgot to add its a 2006 cooper s
Pull the filter, if it's ok you can always chuck unit back in. I used to exclusively use oem filters but have been using Bosch or Mann from ecp for ages now without issue. I have however been supplied with the wrong filter before
Remove the oil filter and check the oil bypass valve and drain back plunger these can cause oil pressure issues if not as per photo.
1 - 5 of 5 Posts
