1 - 3 of 3 Posts
hi guys , i have bought an r57 jcw recently and there is a problem when im stuck in traffic a half full check engine shows up with the writing reduced engine power and the throttle becomes barley responsive and it tends to make pop sounds from exhaust as i push the throttle , as i turn the car off and on it will become normal again, after diagnose this error showed up (2880 high pressure system) along with combustion errors at cylinder 1 and 4 . it is running on 95 octane
Could be a fueling issue fuel filter, intank pump, HPFP.
Does the engine still have good compression?
Almost definitely HPFP.
My exhaust used to pop like mad when trying to drive off. I also had the 2880 fault and also misfire codes.
How many miles has the car done?
1 - 3 of 3 Posts
