21 - 40 of 66 Posts
Here's a pdf on break-in you might find interesting. I couldn't figure out how to send it to you on FB.
Reactions: seb80 and George1
Discussion Starter · #25 ·
[QUOTE = "oldbrokenwind, message: 2505806, membre: 3714"]
Voici un pdf sur le cambriolage que vous pourriez trouver intéressant. Je ne savais pas comment vous l'envoyer sur FB.
[/CITATION]
Thank you
Discussion Starter · #30 · (Edited)
Nouvel outil reçu J'espère avoir le piston Cp la semaine prochaine
J'ai une nouvelle question pour mon projet
Cams modifiés par des caméras Boudis ou une Catcams? Ou des cames de stock?
103187
Discussion Starter · #31 ·
Hello , bad news.....
I want test my tool for reassembly piston on the engine
Impossible to assembly in the cylinder
103198
I measure the ovalisation , bad news ..... 0.15mm
103200
103201
103202
103203
I had 0.04mm max in December..... I don t understand .... before block guard installation
It s the end :eek:
I will receipt my CP piston next week...
First solution :
-disassembly engine and machining to 77.5mm
-sell my new piston (77mm)
2nd : disassembly bloc guard
-i try : impossible
Last solution: cut the bloc guard for decrease the constraint
103204
103205
103206
When I looked into installing a cylinder support system then they installed the brace first then machined the cylinders to account for any deformation caused by the brace. Is it the brace installation that's causing some of the deformation?
An Installation of a block guard like this definitely deforms the Zylinders.
An Installation of a closed deck isn't possible at stock Diameter. You can't correct the diameter.
My question is why you installed it at all?
Discussion Starter · #34 ·
Good news for the first cylinder
Ovalisation 0,02mm after cut the bloc guard
103208
I hope have the same result with the other cylinder
Why i installed this ?
-> it s to avoid a crack cylinder
The better solution would have been a rebore. You're defeating the point of the brace if you cut it to relive the pressure on the cylinder liner...
get a better CSS solution imo, all the gaps around that one are preventing it from functioning optimally surely....
Here's "before" and "after" pics of my CSS installation --- the "before" block was scrapped. Note this CSS was installed and then block surfaced was "skimmed" to make it all one smooth surface. I also chose to use 77.5mm pistons, so a rebore was already in the plan.
Looks like your CSS is mounted below block surface, putting the top of the cylinder wall at risk --- questionable.
I highly recommend you do a rebore to 77.5mm. Altho, if your oval's largest diameter is still within cylinder specs, you might be able to get them all re-bored to 77.0Xmm (max spec diameter), then not have to buy another set of new pistons. Altho, if Arke is correct, an oversize rebore might be the only solution.
The copper ring is for an improved gasket seal and pistons are 9.0:1 CR.
Discussion Starter · #38 ·
Merci pour ton information
après avoir coupé le garde-bloc (pas de déformation plastique sur ce cylindre)
I will continue next week end , I hope have this result on the other cylinder
Video cylinder measure
You avoid a cracked cylinder by not having any detonation/superknock.
21 - 40 of 66 Posts
