And still better than some of the tat you can buy on eBay!cardboard charge cooler....
You might want to edit your name and address out of the picture too!
Why do you think that?trailing arm front bushes are better left OEM really, only opinion etc
I thought that's what you were getting at. I've just changed mine to the softer Powerflex bushes and I was hoping that with the restricted travel of the coilovers and the harder bushes in the Hardrace arms then they wouldn't see too much of an arc. The bolt holes for the bracket are slotted so when I do the wheel alignment I was going to slacken the bolts off and take any preload out of the bush while the weight of the car is on the suspension.the arms move trough an arc over their full travel which poly resists to a degree, the bolt/thread becomes a weak point as it gets loaded,
