also just had a word with my mate and he reckons that if it has gone then it would be due to crank shaft wear which he said would be best to just change engine, is this true or would replacing rear main seal be okay?
No it's not true
You shouldn't have used 5/30 over 0/30 either, both are ok, 0/30 is what any dealer will put in fwiw.
If you've changed or checked the PCV valve then perhaps get some more pics looking at the engine from the rear view looking up showing the bottom of the gearbox and rear side of it, also sump/gearbox joint and bottom of clutch fork.
If the rear main has gone it might just smear rearwards but from those pics already it doesn't look so bad. It is wet around the sump to gearbox joint and the rear sump edge. How much are you adding weekly? And by 'no oil' do you mean just on min?
You'll also see halfway across the sump at the joint to the gearbox at the bottom, there is a small semi circular hole which is a tell tale of input shaft or rear main leaks, but sometimes the leak is clearer from the top left rear corner of the sump to gearbox just below the starter, ideally look across there, but also all the way across the rear sump joint, and also shine the torch up at the oil filter housing looking for leaks where it joins the engine or other leak signs from oil collecting at the back. When cold also run your fingers along the rear of the cylinder head above the exhaust which will reveal rocker cover seal leaks or the timing chain guide access caps at the front perhaps.
They all use a reasonable amount of oil but not that much, and I'd expect to find it quite wet under there for what you say you're putting in.
If useful, guide price: rear main seal £432 plus parts, with engine out so any others will be cheaper if required, as is a supercharger oil service @ only £144 plus sundries, and crank sensor seal @ £parts only, in conjunction with the aforesaid.
