Would imagine, only into reverse lights .Does this require any cables to be cut or tapped into on the car? I like the idea of adding a reversing camera since visibility isn’t great on the convertible.
it dims with the headlights (so will go to night mode/dark mode and will be less bright) - well, at least that's how i have mine set..It looks quite cool. Can you switch off/dim the display for driving at night?
it's fine - not sure what other options you've used or what you find tedious - but CarPlay and Android Auto work flawlessly - as they do in any other car.. and the actual Android interface is fast and responsive.. I've got no complaints.. i know there are a few generic units out there running older version of android and only 1GB RAM etc which i can't imagine would give a great experience... this has 4GB RAM and a PX5 processor so is pretty decent TBF.How do you find the software? There's a lot of chinese android solutions for many cars, but in my experience they are tedious to actually use.
completely plug and play - if you wanted to add reversing lights then there's various options for that - all would require some level of wiring.. the headunit itself though is plug and play.Does this require any cables to be cut or tapped into on the car? I like the idea of adding a reversing camera since visibility isn’t great on the convertible.
Surprisingly good , very responsive and easyHow do you find the software? There's a lot of chinese android solutions for many cars, but in my experience they are tedious to actually use.
If you have OEM AUX/USB or just AUX, they no longer work .Hi,
Thanks for everyone that has contributed to this thread.
Am I right in saying that this doesn't use the Aux input? (Mine isn't working).
And is a "car launcher" just an app you can download onto the device...looks better in my opinion so keen to understand how to replicate.
Cheers
Thanks Ant...If you have OEM AUX/USB or just AUX, they no longer work .
The launcher is called AGAMA, there are different ones , but this was my preference, downloaded from GooglePlay
Just blinking noticed ....doesn't work if you have sat nav! And I do....I have no AUX , I just stream , or use my music apps
Aaaagh , there is one if you have SATNAV but it is KMPH , some guys download a GPS app to show MPHJust blinking noticed ....doesn't work if you have sat nav! And I do....
You just need a lead like this if you want to retain the factory USB.If you have OEM AUX/USB or just AUX, they no longer work .
Just fitted mine 5 mins ago as Amazon just deliveredYou just need a lead like this if you want to retain the factory USB. View attachment 109276
What are you thinking to do with the second USB. I was thinking to stick it in the hidden glove box or something.Just fitted mine 5 mins ago as Amazon just delivered
I bought this, have to thank Pangster for the idea.What are you thinking to do with the second USB. I was thinking to stick it in the hidden glove box or something.
