This is my rca harness the red is the supply to the camera and the yellow rca is for the camera video, nothing else needed other than the camera ground
So totally different from my other harness , very odd, guess auto electrician is needed for me,This is my rca harness the red is the supply to the camera and the yellow rca is for the camera video, nothing else needed other than the camera ground
I was given the update file , but didn’t work for me , possibly due to me having a Mac , and unable to unzip as needed.Hello all. I've just received my android head unit and backup camera. Waiting for the weather to warm up a bit before I tackle the install.
One question - has anyone been successful updating the software?
Curious, where did you end up attaching the ground lead? Thanks.My camera is hard wired so no need to break into any wiring just make a groud.
Thanks, I thought that. I was just wondering if you found a convenient spot to attach the ground wire while you were running your cables.Pretty much anywhere you want a ground is a ground, it doesn’t need a clean ground
Problems with the camera. Can you say more about that?Mine is and miss , have a good ground , but camera works occasionally.
Sometimes comes on , other times not , awaiting a replacement, as all connections are sound .Problems with the camera. Can you say more about that?
Hi,Thanks, I thought that. I was just wondering if you found a convenient spot to attach the ground wire while you were running your cables.
Cheers.
The four pin connector on the camera can cause problems make sure the pins are straight and make proper connections and that the arrows line up. I am you have checked this but worth a second look.I'm about to give up on adding a backup camera. I've attached two videos of what I'm experiencing.
Several back and forth communications with the supplier have been fruitless.
