1 - 11 of 11 Posts
I bought a used miltek cat back system removed from a R53 to fit my R52. While trying to fit it I get the feeling that there should be a different system for each body type and this will not fit my R52. Are the systems model specific or an adjustment to the one I bought to make it clear the strengthening bars?
2003 cooper S 218bhp
I’ve got a Scorpion cat back on my R52 (Mini one convertible) that was originally off an R50 and it took a bit of adjusting because of the strengthening bars, there is very little room for play apparently but it went on easy enough
funnily enough though it’s just started rattling and vibrating on something at the back so it’s going in first thing Wednesday to be adjusted/tightened as it’s rattling against (I assume) the bars
I’ve had a year out of it before it started rattling but also I undid one of the bars when I changed my side skirts the other month so thats probably not helped
If I can get a pic while the car is on the ramps I will
Pretty sure they are model specific with flattened pipework to pass over the bracing AND different hangers pre & post facelift...
Look on the bright side, if you can't make it fit, someone here will take it off your hands & you can kick on from there.
As above, providing you were sensible in what you paid for it, you shouldn't have any trouble getting it back if you can't make it work.
It is more the annoying process of having to find another system while the car is apart, I know I could put the standard system back on but I just don't want to.
Let me See if I can get some pics tomorrow while mine is on the ramps having the scorpion adjusted, you may be able to see where the pinch points are and how my mechanic got round it, the pipe is the same size as the milltek one as far as I remember
is your milltek a centre exit one for a supercharged R52 Or Single drivers side exit as per my mini one?
Discussion Starter #11
Mine is the cooper s with the centre exit. I have been offered a scorpion system which is currently still fitted to a R52 so I will see it on the car first.
1 - 11 of 11 Posts
