201 - 220 of 256 Posts
Hobo Member
Discussion Starter · #201 ·
As the wheels are 7x17 ET42, they would not fit without any spacers in the front. Good that tcbw had a set of 13mm that we slapped in the front so I'd be able to drive home. I have found some Kavs 11mm spacers (set of 4) for sale in Finland and bought them. Few days later replaced the 13mm fronts with 11mm and added a set in the back. Looks much better now, now just waiting for the arches to trim them self.
I'll also remove the decals that are on the wheels, not a big fan of them.
Hobo Member
Discussion Starter · #202 · (Edited)
Lately haven't driven the Mini much. Couple of weeks ago I finally decided to install the 550cc injectors that I have bought couple of years ago. At the end of May I took them to be checked and they came back with a clean bill of health and a note that they should be installed soon.
Only 2 months later I felt motivated enough to do it. I have to say that the old ones were a pain in butt to remove. Only 1 came out with the rail, rest was stuck in the manifold. After getting them all out I was surprised how they looked.
After that the install went much smoother and after a few seconds hesitation the Mini started and after 10-15 seconds the idle was stable. Let it run for few minutes and left it there. After 4-5 days decided to take it for a spin just to be welcome by a non starting shitbox. After turning the key it only clicked once. Connected 13.6V to the battery and no change. Long story short, something drained the battery and after loading it it's working once more.
Today was time to take it to the annual MOT and I had couple of things in my mind why it could fail and the tester came up with 2 different things: lack of rear seats and the car is registered for 4 persons and the rear Hardrace control arms, he wanted to see some paper that they're made for the Mini. Of the first issue I'll take care during the next MOT, will ask to have the papers changed and registered as a 2 seater. For the seconds issue I'll have to think about it.
So at the end of the day everything went well. Now I'm already thinking about getting it into storage for the winter. Maybe during those long cold months the love for my shitbox will come back and I'll be willing to drive it instead of burning it down.
Hobo Member
Discussion Starter · #204 ·
I sold the stock interior this summer. But not really worried about the 2 seater thing. Sooner or later there will be a rear cage going in. As for the paper, tcbw told me that the GP2 had the same issue and it was enough with showing a web page that they're for that model.
Hobo Member
Discussion Starter · #205 ·
Not much happening with the R53. Last weekend was the last track day for this summer and it went well but could have been better, as always. Here's a crappy pic I took in the pits.
Today in the morning I changed the oil and took it to storage in the afternoon. This summer has been a love/hate story with idea's of getting rid of it at some point. Hopefully during the next 6-7 months I'll get some of the motivation back and start having fun.
MiniTorqueGoesFinland
I'm sure you'll get your mini-mojo back. They are all fuckin MINIs right now - I think we're all facing issues of one sort or another, it's just age and a lousy summer for motoring.
Hobo Member
Discussion Starter · #208 ·
Not much happening here. Bought a new alloy header tank to replace the stock one that has been already once replaced. As the car has 172kkm (bit over 100k miles), I'll be replacing the timing chain. The tensioner has been replaced couple of years ago but there was some rattle when driven during the winter. As the oil pump will be taken out, I'll replace the oil pump gears. And trying to improve something at the same time, I bought a 2nd hand ATI crankshaft pulley. And the catcam will be installed also. Besides that some basic maintenance will be done and hopefully it'll be ready to hit the track.
Hobo Member
Discussion Starter · #212 ·
Will have to look into the t shirt thing. It would be nice to have something new for the summer.
As for the Mini, spring time and snow melting must have affected the few brain cells I have leftas I’m looking forward to bringing the shitbox home. Once more a long list of stuff to do, between basic maintenance and all the crap I’ve had marinating in the parts pile should keep me occupied for few days. Not sure if it’ll be ready before the first trackday on 30.5.
Let’s see how 2021 starts and when will the first thoughts of burning it come to my head 😅
Hobo Member
Discussion Starter · #213 · (Edited)
I thought it would be nice to post here a list of stuff what has to be done on the shitbox when it'll be back from the dead:
  • Replace engine oil and filter
  • Replace gearbox oil
  • Replace SC belt
  • Clean air filter
  • Replace cabin filter
  • Install Carbotech pads
  • Clean and grease caliper pins
  • Trim bumper lip
  • Cut out front strut towers
  • Make holes for rear damper adjustment
  • Install alloy coolant reservoir tank
  • Install Forge power steering reservoir + flush fluid
  • Install AFR gauge
  • Install Powerflex upper engine mount bush
  • Install camshaft
  • Replace timing chain
  • Install ATI crank pulley
  • Alignment
Probably 2-3 days of wrenching at my pace. Let's see how motivated I'll be :unsure:
Hobo Member
Discussion Starter · #215 ·
Definitely doable. Some minor stuff can be done at home, other will be easier with a lift, cam and chain with no time pressure. Hopefully the alignment will be the only thing that will have to be outsourced.
Hobo Member
Discussion Starter · #216 ·
New tyres finally arrived R888R in 215/45/17. Was going to get them installed on the white ultraleggeras but found a set in grey with the same specs (et37) and bought it. Was going to paint the white wheels later but it was easier to buy another set and sell the white ones. Also the bronze Work wheels will be sold. So my only tyres will be the Toyo's :ROFLMAO:
Hobo Member
Discussion Starter · #218 ·
Summer and sunny weather only. New tyres probably will not perform well in pouring rain
Hobo Member
Discussion Starter · #220 ·
Here’s a quick pic of the new to me wheels with the rubber mounted. Will have to give them a clean and maybe some coating or wax to avoid the brake dust from XP8’s sticking.
