181 - 200 of 266 Posts
Mr. White Shoes
Discussion Starter · #185 ·
I'm surprised someone hasn't 3D printed something that's a perfect fit (and looks good)
I remember seeing on instrgram that someone made a decent cover, I think it was covered in carbon fiber. but i think it was a one off.
I don't mind how it looks now, without the down tubes and the whole console. But it would be nice to have the lighter and mirror adjustment knob not attached to something
mine's just a sliding fit with an M6 or 8 bolt through the top
The knob that comes with the shifter just slides in and is attached with a bolt from above, as you wrote. But now they also thread the shaft so you can put a different one when you fancy it.
Mr. White Shoes
Discussion Starter · #186 ·
Ticked another thing from the to do list today. First time after installing the intake I cleaned the filter. To be honest, it didn't look that bad. Was expecting something much worse.
And finally could make use of the K&N kit I bought for the bike several years ago
And also installed a MS5150 facelift ECU. Now it pop and bangs like it should have since the beginning. Being an early facelift (7/2004) it came with the old EMS2000 ECU.
Mr. White Shoes
Discussion Starter · #188 ·
Now both are in and the seat airbags have also been coded out so no airbag light on the dash, thanks to the master of coding JKo 😎
I'm quite happy with the result. They're much better than the stock seats, imagined that they'd be slightly lower. >But those are the issues when you have a big head and are too tall.
Mr. White Shoes
Discussion Starter · #191 ·
Last weekend found for sale something I was not looking to buy but just could not let this opportunity pass by. I found a supercharger that comes from an S that was converted to a JCW at a local dealer at some point in 2006. Since then, the charger has been stored and was supposed to be used for something else by the seller. I'll store this for some time, in case I need it in the future.
And also received few weeks ago the cam I ordered locally
Mr. White Shoes
Discussion Starter · #193 ·
Finally done something I was planning for a very long time. The valve cover was leaking as 2 of the threads in the head were messed up. 2 helicoils were installed together with new valve cover bolts and a new gasket, had those laying around since last summer. As the cooler was off, decided to put new plugs, nothing wrong with the old ones. Fingers crossed that I won't smell anymore burned oil when reving higher.
Some maintenance still left to do before going to the track next month with the rest of the guys.
