1 - 20 of 291 Posts
Mr. White Shoes
Micke's Shitbox R53
Bought in 2017 as a daily. Purpose was to keep it stock but shit got out of hand and here we are...
Engine
  • Kavs 17 % pulley
  • Airtec intercooler
  • Orranje stealth intake
  • Samco intake hose
  • Janspeed manifold + tomcat
  • Jetex resonated 2,5” cat back
  • Cat Cams 469 camshaft
  • Bosch 550cc injectors
  • APS 265 fuel pump
  • Bytetronik FA53
  • Baffled sump
  • Kavs idler pulley
  • ATI Super Damper crankshaft pulley
  • Alloy expansion tank with Mishimoto cap
  • Mishimoto radiator
Suspension
  • ST XTA coilovers
  • Whiteline rear ARB
  • Hardrace rear lower control arms
  • Powerflex front control arm rear bushes
  • OMP lower strut brace
  • OMP upper strut brace
  • Cabrio braces
  • R56 trailing arms (not installed)
Drivetrain
  • Quaife LSD
  • Powerflex lower engine mount inserts (big & small)
  • Powerflex gearbox mount inserts
  • Powerflex upper engine mount insert
Brakes
  • R56S Front Brakes
  • Carbotech XP8 front pads
  • Carbotech AX6 rear pads
  • HEL braided brake lines front & back
Wheels & Tyres
  • Oz Ultraleggera 7x17 et37 + Toyo R888R 215/45
  • Sparco 5mm spacers on the front
  • Orranje stud conversion
Exterior
  • Aero front grills
  • Rear wiper delete
  • Rear debadge
  • OEM short antenna
  • Reg plates without EU sign
  • Black belt line
  • White mirror covers
  • Aero spoiler
  • LED tail lights
  • R50 side scuttles with dark indicators
  • TRS tow strap with KND adapter
  • Color coded headlight trim
  • Painted gas cap
  • Painted door handles (planned)
Interior
  • Recaro SP-JK seats (JDM Evo 7)
  • Coolerworx Shifter
  • Innovate MTX-L Plus AFR gauge
  • R56 GP2 seat delete
  • Ultragauge
  • RRS 2kg extinguisher with Puretrack mount
  • R50 shelf under steering wheel
  • R50 glovebox/shelf
  • Union flag rear view mirror cover
  • Retrimmed steering wheel
  • Black carpet (not installed)
Here I was about to compliment you on keeping the S-Lites. Clean car nonetheless. The pulley and airbox really change the feeling of the car. Not a whole lot faster, but the whine and the whoosh of the air into the intake, even at partial throttle... awesome!
Mr. White Shoes
Discussion Starter · #4 ·
Thanks tcbw. Seeing your car gave me some new ideas, good that the winter is coming there'll be enough time to make a plan.
The wheels really made a big change, not only in weight but also ride quality. Even if the profile is lower, the ride is smoother as they're not runflats. And also now it looks different from the other Minis I see on the street.
As I first car years ago I had a Polo G40 already stock was a lot of fun but with a pulley, schrick cam and a tune (or chip back then) it really was a pocket rocket. Unfortunately I was young and stupid and the handling was not the most important thing back then :)
Mr. White Shoes
Discussion Starter · #6 ·
I bought a repair set from Lederzentrum in Germany. Their distributor in UK is www.colourlock.com
I'm really pleased with the result. The after picture was taken just after the dye dried, after some time you I don't notice the difference. Of course it also depends how badly your bolster is worn, mine had some pretty wide cracks so it wont be perfect unfortunately.
Very nice looking configuration you have there, Micke, and top work you've done so far :)
When you refer to having lost 6kg per wheel, you mean in the whole set (wheel plus tyre), right?
Mr. White Shoes
Discussion Starter · #8 ·
Thanks citro. There are still some small things that bother me and require attention, after that I'll start thinking about the mods.
ABout the wheels: yes, it the difference of 6kg was between a set of rim + tyre. To be exact, it was the following configuration:
- S-Spokes (7x17) + 205/45/17 Continental runflat
- OZ Ultraleggera (7x17) + 215/40/17 Nokian Z Line
Mr. White Shoes
Discussion Starter · #9 ·
Today by mistake I found out that a company not so far from where I live is the importer of Powerflex, quite a surprise. I checked their website and the have some bushes for the Mini in stock also. On my way from work I stopped by and bought this, no need to order it abroad.
I also have a new Lemförder lower mount waiting so without waiting too long I popped it in. Now I just have to find a suitable moment to fit it and enjoy the vibrations
Mr. White Shoes
Discussion Starter · #11 ·
Kiitos JKo! I laughed with tcbw that the amount of Finns here just raised by 50% :lol: Ah yes, the wheel gap. It really hurts my eyes but I don't really want to put any coilovers for the winter but they're on the top of the prio list. At the moment I'm leaning towards ST XTA, seems to be a good allrounder as I have thought about some track days during next year.
Mr. White Shoes
Discussion Starter · #12 ·
Not much going on lately, making already plans for 2018 and thinking where to get money for them :crying:
Couple of days ago I got a parcel from amazon which contained this:
I have to say that the bulbs made a huge difference, probably because it looked as the ones on the car were from 2004...
Also during the last morning I noticed that it was hesitating a bit while starting, probably because the mornings are getting colder. Picked up a new Exide 64Ah battery and the problem is gone. The old one probably would anyway die during the winter.
Mr. White Shoes
Discussion Starter · #13 ·
Unfortunately winter is around the corner :scared: On Saturday it was time to get the winter tires on some wheels that I have bought not so long ago. They're not the prettiest but for 1 winter I can live with them. They're Team Dynamics Monza 7x16 et45
At the same time the tires were taken from the Ultras and checked on the balancing machine and unfortunately 1 needs repair :crying: Fortunately it can be repaired, today I should have an estimate. Also called a placed to have the whole set stripped and powdercoated. I have thought to leave them white, in my opinion they look really well.
Also I received a nice surprise today in the post :laugh:
Bob’s your uncle
Those TDs might look better without the centre caps?
Let me know how you get on with the repainting of the OZs, as I have some black rims that need some paint. They look so dull in black on a DS car...
Mr. White Shoes
Discussion Starter · #19 ·
The TD's have a double PCD so they look like crap without the caps. Probably going to use them only for 1 winter as I'm looking for some super or ultraleggeras in 16".
Yesterday I picked up the bent OZ from the repair and it looks good. The only problem I had with all the wheels where the centre spigots as they have been sitting there since 2010 and never been taken out or greased. The spigots are from aluminium but they have a securing ring which is probably made out of steel and was all rusted...
After soaking them in WD40 it was hammer time. After struggling for a while I managed to get all the rings out from the wheels but the hammer and other tools didn't do any good to the spigots and they're bent so I'll have to get a new set from somewhere.
I talked to a guy about stripping and painting them. I'll let you know when I get them back (it seems that there's a waiting time of few weeks at the moment)
1 - 20 of 291 Posts
