1 - 4 of 4 Posts
2003 R53
Hi, I have an opportunity to buy a Malian exhaust manifold for 1/2 price, because mine cracked after the first cat and I welded it. Can someone tell me how good or how bad it is. Because I can buy for little more manifold form fmic.pl and I know the quality is quite okay for the price.
they're probably out of the same place in China,
be aware they have a flange error which is why the flexi's break, unless you cut the pipe, set the position correctly, and reweld it so the system is properly between the central bump stops to relieve the strain, then they can last
Reactions: Sieklo
2003 R53
Okay, thanks :D If I will buy it, I would replace the de-cat pipe with sports cat, so I addition I can fix that problem
Fwiw I have one of their intercoolers on my car. Nice bit of kit and cheap as chips
1 - 4 of 4 Posts
