1 - 10 of 10 Posts
Hi All,
New to Minis, this is my first one so this is all a bit of a learning curve at the moment. I have a 2004 Cooper S with the digital climate control init, cooling system is working great stages 1 and 2 fans work perfectly cutting in at 105 and 112 degrees as expected
However when I switch my AC on the compressor clutch engages and remains engaged, the engine cooling fan initially spins up and runs for a few seconds on stage 1 then just spins down and doesn't appear to come back on.
I am a bit baffled as to what can cause the AC clutch to engage and remain engaged but allows the engine fan to drop off I would have expected them to act together in parallel?
I have attached a few screen shots of a diagnostic package in the hope I am missing something
System Off
100215
System On
100216
Thanks in advance
Ian
Hi All,
System Off
System On
Thanks in advance
Ian
8bar refrigerant pressure is required to trigger stage1 fan.
Thank you but shouldn't stage 1 fan be running up to that point? Stage 1 starts when I first start the AC but after a few seconds cuts out and stays out.
I believe stage 1 is coolant temp(105°C) & 8bar ref pressure triggered. Fan cuts out at 101°C.
112°C coolant temp & 18bar Ref pressure trigger stage 2.
Check your AC system.
Discussion Starter · #5 ·
Right I might have been a bit thick here then, I was expecting the cooling fan to run all the time the AC was running rather than cutting in and out, As that's how my other car behaves. oops :)
In & out of 1&2, temp & pressure dictated, unless you've done the resistor bypass mod.
Discussion Starter · #7 ·
Thank you for that appreciate your help! back to square one with why my AC doesn't work now though, will have to do some more research.
the active screenshot high evaporator sensor temp, with compressor definitely running? I'd be getting that re-gassed to be sure the refrigerant weight is known good personally, not that it's much help for what else might actually be wrong....
Discussion Starter · #9 ·
Thanks for all your advice guys I would have been going around and around in circles! took it into the garage today and it did indeed have a low refrigerent weight (approx 200g vs 500g), all topped up now and working fine :) just a shame the weather here is now awful!
good dehumidifier though 😂
1 - 10 of 10 Posts
