The timing is correct. I cant understand why is the compression so low.Sounds like the timing is out and the valves are not closing.
The timing is correctSounds like the timing is out and the valves are not closing.
The timing is correct. Is there anybody with the same cam to tell as the compress from his car;As above. Check the timing marks.
Is it normal; will i have a problem;very easily - overlap
25% is a bit OTT perhaps but it changes it regardless.
