Is it switched on in your map? I've got a Delphi post cat lambda but it's switched off as the high flow cat kept putting the engine light on. My pre cat is a BoschWhich brand and or part number should I be looking for to replace my post cat sensor?
Thanks.
I'm decat, and presumably nothing was coded out for that. Pre cat is Bosch, but Bosch don't do the post cat so I was wondering which one to go for. I've since seen NTK, Delphi and a genuine item on eBay (£225!). Will probably do NTK at £88.Is it switched on in your map? I've got a Delphi post cat lambda but it's switched off as the high flow cat kept putting the engine light on. My pre cat is a Bosch
If you're running a decat then it's definitely coded out. It won't be doing anything. The only function of the post cat is to tell the ECU if the cat is working or not. All your fuelling is controlled by the pre cat. It might throw a light on if it's gone open circuit but that's all.I'm decat, and presumably nothing was coded out for that. Pre cat is Bosch, but Bosch don't do the post cat so I was wondering which one to go for. I've since seen NTK, Delphi and a genuine item on eBay (£225!). Will probably do NTK at £88.
Interesting, I didn't know that. Maybe then as you say it's gone open circuit? I'd like to get rid of the EML light if I can too. I've a new ventilation tank valve to fit as this also keeps popping up.If you're running a decat then it's definitely coded out. It won't be doing anything. The only function of the post cat is to tell the ECU if the cat is working or not. All your fuelling is controlled by the pre cat. It might throw a light on if it's gone open circuit but that's all.
Thanks George, it has crossed my mind it might be a dodgy connection which I guess is going to be tricky to track down?That's just telling you that the heater in the lambda isn't heating up for some reason. I would try and fix it rather than code it out as it might be pulling the voltage down elsewhere. It could be the lambda sensor or more likely a dodgy connection somewhere. Clear the code first if you can, take the leads off the battery terminals and touch them together incase it's a spurious code that's stuck in the EEPROM, unplug the the harness from the lambda and unplug the ECU and check the connections. Give anything a clean that looks like it needs it and put it back together.
Does the code appear with the lambda unplugged?
Well I've experienced these symptoms a few months after the tuning from 1320. Absolutely not suggesting it's down to them, more to point out I've been managing these symptoms for a while. As it's mostly a daily driver getting to hit boost for flat out sections in London never really triggers anything, it's just those trips out with the boys or some motorway blasts it starts to throw a wobbly. The next drive out I'm going to try and induce the poor running and hit the datalog button to see if that shows up anything.If be surprised if some of this wasn't related. Is it likely that all of these things have failed at the same time? With a pile of codes like that I would start to suspect wiring or an ECU fault. What a time you're having with that bloody car!
It's Bosch for sensor 1 off the turbo, and the replacement for sensor 2 which is yet to be installed is NTK.What make of lambda sensor did you use?
I ask as I only ever trust NTK or Bosch at a push as every other brand I have tried has failed early.
I don't think the battery terminal thing does anything at all, but could be wrong.
It's something that works sometimes if you're writing a new file and there's a code stuck in the EEPROM or you're having problems communicating. It's just to make sure that all the capacitors in the ECU are fully discharged.I don't think the battery terminal thing does anything at all, but could be wrong.
I wouldn't even know where to begin with that George. I can see what happens with new leads and if it persists then I'll clearly need to explore the wiring further. I say "I", more like I'll book it in with Millsys or 1320.Have you checked the wiring for continuity between the ECU and the O2 sensors? Also the supply voltage to the heater circuits. Not sure what it should be but I could look it up on Autodata
