401 - 420 of 461 Posts
Discussion Starter #401
Not much to report over the past 3 months.
But for the first time ever I've had winter tyres on. Couldn't justify the price of some Continental ones for only being on for around 4 months, so got some Nangkang SV-3 which got reasonable reviews.
Got a large crack in the (original) windscreen, no idea how.
Worst news, discovered this after washing the car a few weeks ago. Seemed to have appeared all of a sudden as I never noticed it the previous wash!
Car is booked in to sort that soon...
Discussion Starter #404
When the car was 9 years old, I changed the coolant expansion tank for a genuine oem one, purely as a precautionary measure, as we all know these things eventually leak (shoddy German engineering).
Just when I thought 2019 was going to be an inexpensive year as I have no more modifications planned...
5 years later... yesterday, I noticed a slight leak
Got this on Amazon Prime for £40, next day delivery
Hopefully the car will stop surprising me :crying:
Make sure the coolant hose isn't rubbing on the shifter cables. I've read some comments on that on one of the FB groups, had my mechanic fix the hose so it doesn't touch.
Reactions: JohnnyC
Be careful with the coolant cap! The spring was weak on mine & I ended up returning to my standard tank
Discussion Starter #407
I thought the hoses were all much higher than the shifter cables.
Will check when I change the clutch in a few weeks.
I did have to put a couple of washers behind the nut at the top of the expansion tank as the overflow pipe is welded on at an angle and was touching the bracket for the PS reservoir.
they're well away as you look at the ends but moving back they cross over each other, so the bottom heater hose is just over the cable/s.
Reactions: JohnnyC
I have the OE type screw version with the higher rated screw on cap from the Volvos that Colin (Astroboy) found. If that doesn't work I will take it and have a stant cap and neck welded on.
The Volvo cap has been excellent on mine too (thanks again Colin). I have one of these new alloy ones to try but I'll get a different cap first with a higher venting pressure as the supplied ones aren't great. Always something wrong with the cooling system on these cars.
Are the plastic units still not prone to leak though? Just based on the material they are made of?
Not in the R50 as the tank isn’t under any pressure.
Isn't the tank under pressure in about every car as it raises the boiling point..?
Not sure old chap, I know the cap on the R50 wouldn't hold any pressure as its not a screw down one. I've seen more secure caps on bottles of water, it just flips open like the windscreen washer one.
Reactions: JKo
The r50 cooling system is under pressure, the tank is an overflow and is not under pressure. The pressurised cap on the r50 is next to the cam cover on the right hand side
Discussion Starter #419
Upon sanding down, it was best to cut it out and weld in new metal
The underside was also treated
Just the clutch to sort out now...
I had my bootlid repaired about 2 or 3 years ago, noticed last week it's started to bubble again in the same place.
I assume he just rubbed it down and repainted.
Ps, who did the work for you?
